09-28-2006, 11:25 PM | #1 |
KEEP ON TRUCKING
rear axle help
71 3/4 ton with the eaton rearend.
will a 14 bolt ff bolt in with no mods. if so what do i need to get it from.
72 cheyenne 2wd lwb 71 k20 sons bassett va |
09-29-2006, 08:10 AM | #2 |
Re: rear axle help
I`d like to know,too.I`m not sure if the spread on the spring pads is the same or if the driveshaft length and u-joints are the same.As far as what it`s out of,they`re all the same`73-up.But,the 4wds are narrower between the springs and`88-ups have a wider spread there on both 2wd and 4wd.
09-29-2006, 10:06 AM | #3 |
Re: rear axle help
You'll have to relocate the spring perches and you may have to engineer some e-brake stuff. Drive shaft should be fine.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's 1970 K5 TBI conversion lifted etc SOLD 1968 C20 camper truck SOLD “To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder |
09-29-2006, 12:11 PM | #4 |
Re: rear axle help
The 14 bolt ff from a 1 ton will have the correct spring perch placement for a 67-72 4wd. The driveshaft will require a conversion u-joint. I can't help on the driveshaft lenght issue. The hard brake line terminates in a different location so you will have to modify that some. Shock tabs may have to be relocated.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 09-29-2006 at 12:12 PM. |
09-30-2006, 12:06 AM | #5 |
KEEP ON TRUCKING
Re: rear axle help
thanks
