Old 10-02-2006, 11:17 AM   #1
el curioso
el curioso's Avatar
5x5 to 5x4.75 bolt pattern?
has any one ever done this aside from having to re drill the front rotors like adding ones from cars or some thing like that. The reason is that the wheels that i bought for my truck happen to be that bolt pattern. I know stupid buy some that fit , but they dont make them.
Any help greatly appreciated.
Thank you in advance.
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 10-02-2006, 12:53 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: 5x5 to 5x4.75 bolt pattern?
You will need to have your rotors re-drilled to 4.75", machine the nose cone down to 2.750 and then mill off the cast ribs on the back so the studs will fit... I've done it a few times! It's the only option... unless you buy a wheel adapter, which will add a couple inches on each side to the track width.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-02-2006, 08:24 PM   #3
ed455
Captain Ed
I've always wondered if anyone has ever tried to fit GM A-body rotors on truck spindles or A-body spindle AND rotors on our trucks. The rotors on A-bodies up to the late 70's are the same outer diameter and GM used common parts on a LOT of vehicles.
4.75" bolt pattern opens up to MANY more wheel choices. Weld rodlites (a beautiful wheel IMO) for instance are not available in 5x5 pattern.
It seems like I remember some of the early disk brake conversion kits used car rotors and spindles.
If you ain't bleedin', you ain't workin'!
1999 C3500 LS 7.4L
ed455 is offline   Reply With Quote
Old 10-02-2006, 10:14 PM   #4
SCOTI
SCOTI's Avatar
My 74 has re-drilled front rotors just like Porterbuilt described.
For the rears, I had the rear axles & drums re-drilled & for the 74 I used billet adapters because it was easier & put the wheels exactly where I wanted.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-02-2006, 11:33 PM   #5
qksilver
My memory isn't the best but for some reason something about a camaro 1le brake option comes to mind. Don't know what year but it is a 12 rotor with the smaller bolt pattern. it was an option on third gen camaro's for showroom stock racing(road racing). Definity can't remember which wheel bearings are needed.
The guys on third gen should know
disclaimer.............it's late, I am tired and medicated!
qksilver is offline   Reply With Quote
Old 10-03-2006, 08:31 PM   #6
SCOTI
SCOTI's Avatar
You could prob cross reference a Hollanders manual to see if the inner/outer bearings for each are the same. If so, they would swap & be the correct pattern.
Of course, you would still have to redrill the rears though.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-05-2006, 01:53 AM   #7
abadsvt
abadsvt's Avatar
Anyone have an idea on what it might cost to have the rotors redrilled? I just ordered a set of wheels in the 4.75 bolt pattern and am in need of some redrillin.
abadsvt is offline   Reply With Quote
Old 10-05-2006, 10:36 PM   #8
SCOTI
SCOTI's Avatar
Check Mosers website. Seems I remember it being about $80 ~ $100 for a pair of rotors.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-06-2006, 12:25 AM   #9
Col Clank
Moser website says $60 for a pair of front rotors. Really not a bad price, may have to look into this when I start looking for new wheels...
Col Clank is offline   Reply With Quote
Old 10-06-2006, 12:59 AM   #10
abadsvt
abadsvt's Avatar
What is there website url? I would like to check them out. I am in need asap. Thanks Josh
Old 10-06-2006, 11:15 AM   #11
abadsvt
abadsvt's Avatar
I found the url. Here it is if anyone else needs it. http://www.moserengineering.com/Page...pservices.html
Old 10-07-2006, 07:37 PM   #12
el curioso
el curioso's Avatar
I was down at the machine shop and The machinist brought up an idea :
That why not plug the 5x5 holes and redrill 5x4.75 holes in the same area rather than milling the rear fins off. I dont mind having to mill the rear fins its just that the less work the less $$ involved. Another question the rear axle shafts when getting milled what do i need to mill the center of the axle to?
Old 10-07-2006, 08:19 PM   #13
SCOTI
SCOTI's Avatar
.... Another question the rear axle shafts when getting milled what do i need to mill the center of the axle to?
Take your new wheels to the machinist & have him measure the hub. The difference is how much you'll need to machine off the axle hubs.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-07-2006, 08:43 PM   #14
uncle
On the rotors, you might try an early chevy or gmc 1/2 ton van Some of them had a 4 3/4 bolt pattern. It's the bearings and bearing depth you'll have to check.
uncle is offline   Reply With Quote
Old 10-07-2006, 10:23 PM   #15
PBFAB.COM
PBFAB.COM's Avatar
Sounds like more work to me... welding up the holes and then re-driling them. Maybe it would be the same amount???? But I would rather mill off the fins.
2.750" should work just fine for a spec!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-08-2006, 12:49 PM   #16
424shee
I bought a running gear recently,switched everything over to my truck about two months ago and am getting ready to get wheels when I read this thread it got me curious about my bolt pattern,so I went out this morning and measured my bolt pattern,from center bolt to center bolt is 4 and 3/4.I have a 69 camaro and I have tried to bolt those wheels up but I could'nt get them to fit.am I measuring eveything right?
424shee is offline   Reply With Quote
Old 10-08-2006, 03:25 PM   #17
PBFAB.COM
PBFAB.COM's Avatar
The bolt pattern is measured as the diameter of a circle that would pass through the center of all the studs. If you measured from one stud diagonal to the one across, on a five lug, it would not be the actual measurement of the diameter... but smaller. If you have a five lug and it measures 4.75" from stud center to stud center on the diagonal, it would take a 5" diameter circle to touch the center of all 5 studs... your bolt pattern is 5 on 5".
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-10-2006, 11:39 PM   #18
Frizzle Fry
Frizzle Fry's Avatar
There is another option. I'm running 4.75" wheels on my 5x5 gear. The pic says it all... But I did pay $180 for 4 adapters. Why? because the wheels were basically free...
Frizzle Fry is offline   Reply With Quote
Old 10-27-2006, 04:47 PM   #19
raggedjim
raggedjim's Avatar
Uncle is right the mid 70's G10 van has some parts than will bolt in (on the front, not sure of the rear) Someone on here had done this but the post was a LONG time ago. I'll see if I can find it.
Rg
raggedjim is offline   Reply With Quote
Old 10-30-2006, 09:33 PM   #20
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
Frizzle, where did you get those? How much space do they take up? Details details my friend.
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 10-30-2006, 09:47 PM   #21
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
yeah, ive got a smoken deal on some car 4.75" slot mags that i would love to run if i had 4.75" pattern
trkklr77 is offline   Reply With Quote
Old 11-04-2006, 03:18 AM   #22
Frizzle Fry
I got them from this guy http://motors.search.ebay.com/_W0QQsassZgotdubs20 You can email or call him to make any specs you want. I think there is a minimum thickness of 0.75" or 1". Mine are 1.25". He does very good work and stands behind his products. I've been running these for a couple years now with no issues.
Old 11-05-2006, 12:04 AM   #23
SCOTI
SCOTI's Avatar
For practical purposes...... 1" thick is the minimum.
Good luck finding a shallow enough lug nug to fit within the <1" spacer. Yes, they make 'custom' shallow lug nuts but even they aren't enough on some wheels (ask me how I know ).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-05-2006, 08:41 AM   #24
entourageguy
Yellow truck club
entourageguy's Avatar
Well gosh I just have to ask then "How do you know SCOTI"
There it's been said...
Brian...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 11-05-2006, 08:47 PM   #25
SCOTI
SCOTI's Avatar
They offer a 7/8" adapter as the narrowest available so thats what I got.
But..... there was no mention that shallow lug nuts would be required if the wheels being used did not have 'reliefs' on the mounting surface. TT2's do not have the reliefs & the search was on for the shallow lugs. After receiving in the more expensive shallow lugs, they weren't shallow enough & the wheels still would not sit flush on the adapter.
The solution was an 1/8" spacer between the adapter & the wheels mounting flange which is why 1" should be the minimum cause I still had to buzz the ends of the lugs/studs w/the grinder to keep things from contacting each other. Frustrating experience......
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
