Old 10-04-2006, 01:14 PM   #1
VA_short_67
VA_short_67's Avatar
Electrical Prob. in 67 pickup
Looking for some help.
I have a 67 pickup.
Restored but all the original wiring appears to be there.
When I start up the truck a get a dim alternator light (no gauge).
Then if I turn on the wipers, or the turn signal, or the heater blower, the light gets bright and none of the features operate.
Just replaced the following:
Starter switch
Alternator
Volt Regulator
Battery
Any Ideas?
I posted this in the electrical section also.
Jay
VA_short_67 is offline   Reply With Quote
Old 10-04-2006, 02:42 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Electrical Prob. in 67 pickup
Check this web page for lots of information. I suspect that the no. 3 wire on the voltage regulator is not sensing the voltage in the wires going to the splice in the picture below. I would try running a jumper from the battery positive post to this terminal and see if the alternator charges.
be sure and clean the connections at the horn relay as it says in the article.
Here is the splice
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-04-2006, 03:40 PM   #3
cdowns
cdowns's Avatar
disconnect and clean the ground wire from the voltage regulator to the radiator core support and the core support to the frame with sandpaper see if that helps// cant stress the importance of stripping and cleaning grounds they're what makes things work
as far as that nifty little diagram up there NOTHING WILL WORK !!! thteres no ground
Old 10-04-2006, 03:57 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Don't worry about the horn relay stuff, the trucks didn't power the cab off the horn relay like they did on cars of the same time period.
Old 10-04-2006, 07:43 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
That explains why mine wasn't wired like the pic. I just thought someone had re-wired it. VV
VetteVet
Old 10-04-2006, 04:17 PM   #6
truckdude239
truckdude239's Avatar
me i just did an internal alt swap http://67-72chevytrucks.com/vboard/s...d.php?t=119379 cost me 40 buxs
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
