Old 10-06-2006, 02:30 AM   #1
etg
etg's Avatar
Finally got my engine
So I finally got my engine back. I didn't really specify what I wanted in the engine, I just sorta said gimme an engine that works to the guy. I gave him a 305 apparently, which he got a 350 core for but kept the 305 heads. What kind of hp can I get out of this? How about reliability? This is a low buck daily driver so there really isnt a need for performance, but I would still like a quick lil truck. Also, I bought an edelbrock carb, flexplate, fuel pump, distributer, and some other stuff from summit racing. I have everything to put the tranny and engine together and drop em in. YAY. Stuff is finally getting done, but slowly.
etg is offline   Reply With Quote
Old 10-06-2006, 11:08 AM   #2
Ole Blue 68
Ole Blue 68's Avatar
Re: Finally got my engine
So what did you wind up with, a 305 or a 350?
Ole Blue 68 is offline   Reply With Quote
Old 10-06-2006, 11:16 AM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
I'm not too good with motors.... but aren't 305 heads essentially 350 heads? The only real difference is with the piston bore in the blocks?
In terms of 350 vs 305 if you want a "quick little truck" you'll be much happier with the throttle response from the "350."
I had an 86 Z28 camaro with a 305 (kinda funny, huh?) and my old heavy truck with a 350 could smoke the camaro....kinda sad actually....
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-06-2006, 05:43 PM   #4
Billla
Billla's Avatar
IMHO you really need to find out what CR and what cam you got - the only way to get the right components together is to know what you got from the builder. They should be able to provide the head cc, CR and the cam card. Without that, it's just guessing...
Billla is offline   Reply With Quote
Old 10-06-2006, 06:06 PM   #5
68GenIII
I think the 305 heads have a smaller chamber = more compression.
68 lwb to swb Cummins swap in the works. I promise it will be cool someday.
68GenIII is offline   Reply With Quote
Old 10-06-2006, 08:57 PM   #6
Billla
Billla's Avatar
Depends completely on the piston, stroke, head gasket compression height, overbore, etc. Without knowing that stuff there's really no way to tell...
Old 10-06-2006, 09:06 PM   #7
68GenIII
Yes and no, the 305 head has a smaller cc combustion chamber.
Old 10-06-2006, 09:46 PM   #8
dirtball
dirtball's Avatar
I think stock 305 heads have smaller valves too. I think it was a bore clearance issue.
dirtball is offline   Reply With Quote
Old 10-06-2006, 11:27 PM   #9
Billla
Billla's Avatar
Maybe I'm misundestanding your point, but without knowing the specific setup making a head change isn't a great idea. Typical 305 heads are 60cc, vs 350 heads of 64cc, 70cc, 76cc, etc.
As an example, if the engine was set up with 76cc heads with -4cc pistons for 9.5 CR , a change to a 305 head would give 11.4 CR...which isn't possible in a Gen I on pump gas. Yes, you get more compression...more than is streetable.
Vortechs are 64cc; a +4 cc change = ~-.5 CR. Vortechs require an intake change as well. Best heads for the $$$, and the best deal in the universe
"Camel Back" or "Double Hump" heads were available in both 64cc (1970 and earlier) and 76 cc (1971 and later) chamber sizes. If the engine was set up for 9.5 CR with a 60 cc chamber, a 76cc chamber would give 8.1...yech. Definitely agree that they're not bad heads for <= .500 lift; Chevy still carries them brand new w/64 cc chambers under P/N 88958692 :-D
Suggestion is to post the casting numbers and let's see what you've got...but I would still get a full build sheet from your builder otherwise you'll play guessing games every time you want to upgrade.
Old 10-07-2006, 04:18 PM   #10
Werewolf
Woof?
Werewolf's Avatar
Sometimes budget guys will use the 305 head on a stock 350 to boost the CR if you're running a stock eco cam, just to get some more spunk out of the engine. An older 350 with a stock cam isn't ever going to see higher RPMs anyway, and the CR is low to start. What, 8:1? Anyway, they did it for better power despite the valves being smaller and max flow being reduced.
Better off, by far, with a new set of heads. That is, if you want to make real power.
1968 LWB CST BB
2004 Avalanche Z71 LT3.
2003 S-10 ZR2 (hers).
1997 Astro
1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck.
1997 Saturn - need gas mileage from something!
Werewolf is offline   Reply With Quote
