Old 10-13-2006, 08:30 AM   #1
hchad18
hchad18's Avatar
Rear air bag mounting
I'm mounting my rear air bag and have the one 3/8" bolt that goes through the trailing arm. Is that enough to hold it? Seems like there should be more.
hchad18 is offline   Reply With Quote
Old 10-13-2006, 08:45 AM   #2
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Re: Rear air bag mounting
yupper, right through the arm
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 10-13-2006, 09:21 AM   #3
67chevemall
67chevemall's Avatar
I want to start with two firestone bags in the back.
Can you take some pics of your project? That would be great!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 10-13-2006, 12:19 PM   #4
72 Cheyenne402
72 Cheyenne402's Avatar
Is it possible just to remove the rear springs and replace them airbags with little modification and keep the front springs? Are there kits for this mod?
1972 Cheyenne 402 LWB
2005 Silverado X-Cab 5.3L
2004 John Deere L120 20HP B&S
72 Cheyenne402 is offline   Reply With Quote
Old 10-13-2006, 01:14 PM   #5
67chevemall
Thats what I'm working on too. Turns out my springs are producing different hieghts from softness or size. I'll fill mine with a air compressor for now.
Old 10-13-2006, 01:14 PM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
Yep. You don't need a kit. Two bags, fittings, air line, and a couple of shrader valves to fill 'em. <---Less than $200 -Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-13-2006, 01:16 PM   #7
67chevemall
i see in other threads that some bags "install" easier then others.
Do you need to take the bed off to drill out the holes?
Does anybody have a template as to where to drill the holes for Firestone 2600 bags?
Cheers,
Old 10-17-2006, 10:25 AM   #8
CentralCoaster
CentralCoaster's Avatar
Which vendor, and which bag? Firestone seems to have a bunch of em, Is there a kit by chance, or do I need to adapt a latemodel kit?
http://www.suspensionconnection.com/...tion/to=r.html
Not to hijack the thread, but I want to bag the rear only also on my 69 C10, with something that will have good load carrying capacity when aired up, and be able to drop the back about 3" when I'm not.
CentralCoaster is offline   Reply With Quote
Old 10-13-2006, 01:31 PM   #9
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
The 3/8" bolt is fine, just make sure you use grade 8 hardware.
67chevemall: For the template, I just took a piece of paper and traced the holes from the bag, then cut them out and mocked it up on the frame with a white marker. It was easy to drill the smaller mounting holes for the bag, the port hole (1") was the PITA.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-13-2006, 04:25 PM   #10
Shane
Shane's Avatar
You're better using 2,400 lb. bags in the rear ... use the 2,600 lb. bags in the front.
Shane is offline   Reply With Quote
Old 10-13-2006, 04:48 PM   #11
67chevemall
2-2400 bags are on order. Bed has to come off for sure.
My torn nails will lower her and the air pump will make her stiff.
Can't wait.
what is the best way to drill a fn 1" hole through hard steel?
Old 10-13-2006, 05:46 PM   #12
67Fleet
67Fleet's Avatar
The bed doesn't have to come off. I did the rear on mine w/ the bed on. You're gonna spend way more time removing & replacing the bed than it will take to mount the bags and plumb the rear.
As for the best way to drill a 1" hole? I started with small bits and worked my way up, also used a unibit, and a die grinder. It takes patience more than anything.
-Bret
Old 10-14-2006, 08:26 AM   #13
67chevemall
cool.
anybody have some pics of the upper mounts?
Old 10-14-2006, 05:47 PM   #14
gringoloco
A guy with a truck
gringoloco's Avatar
Here.
-Chris
Old 10-17-2006, 06:03 PM   #15
gringoloco
A guy with a truck
gringoloco's Avatar
Check out *****************. They have everything you will need at the best prices. If you have technical questions, call 'em up and they will set you up with exactly what you are looking for.
<-- Not affiliated with SD, just a very satisfied customer.
-Chris
