10-14-2006, 07:46 PM | #1 |
Blue 67
Finally found the right Bearings
Well, after lots of delays and assembling and disassembling I learned in a hard way that I have to test fit every single part before putting things together. Finally I found the right bearings, race and seals for my truck. I am gona write some part numbers for those who may looking for these parts.
outer bearing: (comes with race)KB-11630-Z Outer bearing race alone: NAPA 362-A Inner beaing: (comes with race)KD-11786-Y Oil seal: NAPA 28426 By the way, as usual I am confused about inner/outter bearing. I call the one close to the rear diff inner which are bigger. They are right under the seal. If I am wrong please somebody correct me. Thanks for the people who helped me along the way. Oh by the way these are close to final pics. Now I have to challange myslef ,again, by trying to bend some break lines.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
10-15-2006, 10:18 AM | #2 |
Re: Finally found the right Bearings
Got to admit that's the first 3/4 ton rear disk brake setup I have seen. Very nice!
10-15-2006, 12:40 PM | #3 |
Nima - Spill the beans about the rear discs.
1. What rear end - Eaton or Dana 2. A kit or your own engineering 3. Pictures or diagrams of the caliper brackets That sure looks good - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
10-15-2006, 02:26 PM | #4 |
Blue 67
It is eaton 3rd member on y 67 3/4 ton. It is the original axle. It is a kit from blackbirdscustom. I wanted to put the parts together myself but after getting prices and reading other threads, it would make more sense to get the kit since everthing is new or quality rebuilt. There should be a picture of brakets somewhere in my computer, I'll try to find it but you can also find it on the blackbirdscustomtrucks.com. My main problem was finding the bearing which are finally done. Also othet thing came to my mind, when I changed my front drum to discs the wheel studs changed to 9/16". My originals rear hubs had 1/2" holes. Instead ot drilling the hubs ( I am mechanically challenged ), I made a trip to j yard and picked up a pair of 71-72 rear hubs which have 9/16" holes. Now I have 9/16" all around .
10-15-2006, 04:28 PM | #5 |
Thanks Nima.
