10-15-2006, 11:25 PM | #1 |
identifying sbc harmonic balancer?
i bought a truck and the balancer is bad, slid back and hit the timing chain cover, so i get another off a supposudly 350, well its a lot taller and skinnier, mine is short and fat, how do you identify these? my engine is suppose to be a 350 THANKS!!!
matt
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
10-16-2006, 12:49 AM | #2 |
Re: identifying sbc harmonic balancer?
Pics would help. What is the diamater of your old one? They came in 6" and 8" diamaters. Wide balancers are 350 and thin balancers are 305.
Aaron |
10-16-2006, 07:02 AM | #3 | |
Weekend Warrior
Can you give me some dimensions - or pictures? Actaully the 6" "Wide" balancer is for a 305 - and the timing mark may or may not be in the correct position. the 6" "Skinny" balancer is for a 350 the 8" balancer is for a 350 the 8" with a big notch cut out of it is for a 400
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
10-16-2006, 09:39 AM | #4 |
The 305 and 350 dampers are interchangeable. After all it's the same crank.
10-17-2006, 09:35 PM | #5 | |
Weekend Warrior
and technically a 305 crank is 3.45" Stroke and a 350 Crank is 3.48" Stroke
10-20-2006, 09:16 AM | #6 |
Never heard of 3.45 stroke. Only 3.48, and I've personally pulled 2442 casting # cranks out of 305's and 350's. Same casting # means same crank. And if the balancer is clocked different just use the corresponding timing cover.
