10-18-2006, 04:24 AM | #1 |
rack and pinion on stock style c-member?
has anyone got any pics of this setup at all? i realize theres lots of options with the dropmember and all, but i just dont have that kind of loot. and i searched and read around, but found nothing. if theres a relatively 'easy' (i know nothing is easy) way to do it id appreciate any info. thanks!
10-18-2006, 07:09 PM | #2 |
Re: rack and pinion on stock style c-member?
Any of the ones I've come across on the web are 1-off set-ups. I've yet to see anything commercially available except for Porter's 'Dropmember'.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-18-2006 at 07:09 PM. |
10-18-2006, 08:51 PM | #3 |
Hollister Road Co.
One of the issues is the lower a frame hits the Tbird or pinto rack mount. I had to modify my stock A frame to clear. If you used tube style id may be ok.
The other issue is getting the rack back far eniugh so the tie rods are straight. I had to cut back the rounded part in the front so it was straight across the front. |
10-18-2006, 08:52 PM | #4 |
Hollister Road Co.
The third problem is the rack shaft. I had to rework the motor mounts . set it up higher and carve our a spot for the ujoint to fit. Once you get past that its a sweet deal. You will need a pressure regulator from Hieht's for a gm pump to Tbird or ford rack. some ujoint and 3/4" stte rod to make the shafts with. test fit with 3/4" wood dowl stock. Its cheaper and easier.
10-19-2006, 06:59 AM | #5 |
Nice install, did you line up the ETO rack's pivots w/ the 2 control arm cross shafts?
10-24-2006, 08:34 PM | #6 |
wow.. that looks pretty good, but i dont know if i wanna cut and modify that much stuff... maybe if i get a few extra front clips ill give it a shot. i appreciate the reply!
