Old 04-23-2002, 09:32 AM   #1
2nova2
Post Starter/Shim ??
The Starter on my Burb started acting up, it would click when i turn the key almost like bad contact so i swapped for another i had that i thought was good, it did the same thing. If i tap on solonoid i here it retracting like it was stuck then it will start! I don't think both starters are bad (solonoid) I have heard of shimming the starter could this keep the soloniod from hanging up and where do i get these shims?
72 GMC Burb barn door 4X4 350/350 PS PB Tilt
62 Chevy Nova Convertible
64 Chevy II V8 Loaded Wagon
VW Offroad buggy
84 700SC Honda Nighthawk
72 GMC Burb barn door 4X4 350/350 PS PB Tilt ( gone but not forgooten)
2004 Chevy 2500 HD
Sonoma County, Northern CA
2nova2 is offline   Reply With Quote
Old 04-23-2002, 11:32 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
Chances are the shims won't do any good for the solenoid, if it's not trying to crank. The are there to adjust tooth contact with the flexplate. It could be a bad ground with the block. If you need shims, they are available from any parts store, and sometimes in a variety pack. Also, some junkyards keep a box of them around.
Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
Angel girl: 67 Cutlass convertible
330, 3spd stick
Greener: 90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
no name yet: 72 442 under serious construction
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-23-2002, 12:47 PM   #3
Rabid
Rabid's Avatar
Post
I shimmed my starter 5 years ago with a piece of a crushed beer can. Stomped the can, cut out a little "C" and put it up around a bolt. Worked like a charm.
Rabid is offline   Reply With Quote
Old 04-23-2002, 02:35 PM   #4
2nova2
Post
O'l Buck The Solonoid pushes the small gear out to contact the flex plate, but what seems like is happening is its not contacting properly and getting stuck out! If i tap with a hammer it releases and i can start or it will jam again. I think the ground is good as well as the battery posts and cables clean.
VW Offroad buggy
2004 Chevy 2500 HD
Old 04-23-2002, 06:44 PM   #5
69 longhorn
Post
it might be too tight dude. A fast tip on starters.......slide a 1/8" rod between the armature shaft & the OD of the flex plate.....not loose,but not tight,& you are shimmed properly.....69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
