Old 10-23-2006, 01:56 AM   #1
skokie
skokie's Avatar
How did you run your HEI plug wires?
I am going to install my HEI distributor tomorrow and I can see some issues with running the plug wires. If you have #1 on the front right corner terminal it looks like you will have a issue running #2s plug wire. Is it better to have #1 on the front left instead? Any suggestions?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 10-23-2006, 02:32 AM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: How did you run your HEI plug wires?
i'd have to go double check, but i'm pretty sure i ran my with 1 in the front driver side. I used a set of NAPA brand wires, and it is a 283 if that helps.
IvelDesigns is offline   Reply With Quote
Old 10-23-2006, 11:07 AM   #3
skokie
skokie's Avatar
So facing the dizzy that the right front. HMM if I go that route then #2 is going to have to be wrapped around the back of the dizzy then go down to the wire loom. Forgot to mention I am running ram horns on the 350 so I am going down and around with the wires.
68 build thread
Old 10-23-2006, 11:23 AM   #4
woodridge
woodridge's Avatar
Wires for a 75-80 vette work very well, they were routed just like the trucks and are HEI.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 10-23-2006, 11:28 AM   #5
skokie
skokie's Avatar
Yep I got the wires for a 78. But how do you route that #2 wire? All the others are pretty simple just having problems with #2
68 build thread
Old 10-23-2006, 12:00 PM   #6
1972gasser
1972gasser's Avatar
On my 400 I used un-cut wires on my HEI and routed them using moroso wire clips on edge of valve covers with a heat proof zip tie at the point where they split to the cylinders between the header pipes I'm running straight plug 2.02 heads. wires are accell race 8mm
1972gasser is offline   Reply With Quote
Old 10-23-2006, 05:08 PM   #7
skokie
skokie's Avatar
I think I have enough wire to go around the back. I will have to check tonight. Lets hope so I wanna get my truck running.
68 build thread
Old 10-23-2006, 09:43 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
This thread in the FAQS may be of some help.
http://67-72chevytrucks.com/vboard/s...d.php?t=191592
Here is a pic that I found.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-23-2006, 11:14 PM   #9
woodridge
woodridge's Avatar
One thing to remember is you don't have to start #1 where the book shows, you can move the order one direction or the other to make the wires work just remember to set the dizzy to line up with where you put #1.
Old 10-23-2006, 11:41 PM   #10
skokie
skokie's Avatar
Thanks VetteVet that is what I needed. Sorry but I am a visual kinda guy sometimes I NEED TO SEE IT LOL Woodridge I was told that as well and was about to try it if I could not figure it out. Thanks for all the help guys. Greatly appreciated.
Also who's engine is that? Looks good. Are those shorty headers?
68 build thread
Old 10-24-2006, 01:38 AM   #11
skokie
skokie's Avatar
Ok its all done. Hei is installed and wires are run. I barely touched that key and it fired right up. I was at 5-6 degrees and I adjusted it to 8 degrees then let it warm up. After that I turned it to 10 degrees and its purring. My wires are not as neat as the pic above but its working. What kind of wire looms are those? Kinda hard to see in the pic.
68 build thread
Old 10-24-2006, 09:16 PM   #12
casterbuster
Mejor Que Nada
casterbuster's Avatar
I make all of my own wires...
The only thing that separates
"Dreams" from "Reality"
is TIME and MONEY!!!
casterbuster is offline   Reply With Quote
