Old 10-28-2006, 12:22 AM   #1
us111
radiator hose prob's
HI all,,hate to double post but maybe someone here can help... (posted on general board)..truck is a 1976,k-10,shortbed,stepside..motor is a 5.7 out of a 1999 caddilac escalade..problem is the *bottom* radiator hose hit's the front cross member and kink's it...was just trying to see if anyone else has had this problem ,and if so what the fix was before i go to the part's store and start digging for something that will work?? thank you all for any help....
us111 is offline   Reply With Quote
Old 10-28-2006, 10:12 AM   #2
Baer
Baer's Avatar
Re: radiator hose prob's
You may have to get one of those "corrugated" hoses, they seem tougher than stock hoses, plus they will bend. It may be difficult finding one tho. Either that or find a hose that has a bend right on the end to clear the crossmember.
Baer is offline   Reply With Quote
Old 10-28-2006, 11:08 AM   #3
cdowns
cdowns's Avatar
seee if turning the hose end for end improves it and maybe you need to trim the length to alliveate the kink
Old 10-29-2006, 10:21 AM   #4
qksilver
might need to go to an exhaust shop and have them bend a pipe to angle it away from the crossmember then use 2 shorter hoses or a radiator shop to rotate the lower inlet/outlet, are they reverse cooling? Don't know
I think I spelled everything correctly
not sure of the grammer though
qksilver is offline   Reply With Quote
Old 10-29-2006, 11:43 AM   #5
us111
hello,thanks for the suggestions so far.it is reverse cooling,the outlet of the water pump is larger than the inlet on rad so can't swap ends..i know i have seen a fix on the site but can't find it..gonna think on some of the suggestions so far..thanks
