10-28-2006, 08:37 AM | #1 |
Active Member
Neutral Safety Switch
I'm installing a neutral safety switch on a truck that did not previously have one. The switch itself is in the trans. (Keisler 5-speed) Any suggestions on the best way to wire it?
Thanks.
The older I get, the faster I was!! |
10-28-2006, 09:27 PM | #2 |
Active Member
Re: Neutral Safety Switch
Any thoughts?
10-28-2006, 09:33 PM | #3 |
its all about the +6 inches
personally, i say remember to depress the clutch.
However, you could run the purple wire that goes from the ignition switch, run it to one of the wires on the switch, then the other wire on the switch, goes back out to the purple wire and on to the starter. |
10-29-2006, 01:33 PM | #4 |
blood type; Retumbo
just an idea here. get one from a 88-98 Chevy truck. its a simple pad type switch that get pushed by the pedal arm. I think it would be fairly easy to fab one of those in. a relay may be needed though.
10-29-2006, 07:23 PM | #5 |
Msgt USAF Ret
I'm not familiar with that tranny but is it possible that the switch is a back-up light switch?
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
10-31-2006, 06:22 PM | #6 |
Active Member
No, the Tremec has a separate back-up light switch on the driver's side and a neutral safety (Ford-type) on the passenger side.
