10-29-2006, 09:25 PM | #1 |
Toggle switch?
There is a switch mounted down below my key hole on the underside of the dash in my 72, and the sad thing is I have no idea what it is for. I've flipped it but nothing ever happens. The guy I got the truck from didn't know either, and I think that the guy who originally restored it passed away. Would this switch be used for something common on these trucks? It's frustrating me that I don't know what this is for.
10-29-2006, 09:29 PM | #2 |
Re: Toggle switch?
If there are wires connected to it. trace them down. I was working on a truck and it had a toggle switch that the owner had no clue of where it went. So I traced it down and found out it was going to the A/C. compressor clutch. Somebody could have put this in as a poor boy theft deterent. etc.
10-29-2006, 10:22 PM | #3 |
BlahBlahBlah
Re: Toggle switch?
Wonder if the neighbors garage door opens and closes when you flip it?
I had one of those on my burb. I found out it changed the horn. Someone installed a set of airhorns...toggle towards me and push the horn ring, stock horn, toggle away and push the horn ring, air horns. |
10-30-2006, 04:14 AM | #4 |
Re: Toggle switch?
If you have [or once had] aux fuel tank, it could be a fuel select switch.
Or maybe it was for the CB. Position 1 = barefoot, Position 2 = 100 watt linear.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 10-30-2006 at 04:15 AM. Reason: thought of something else |
10-30-2006, 05:54 AM | #5 |
Re: Toggle switch?
could be for rocket launcher// or maybe for spraying an oil slick in back of truck// or to turn off brake lights OR OR OR ????
10-30-2006, 07:45 AM | #6 |
Sisyphus was my mentor!
Re: Toggle switch?
i was gonna say that mabe the deceased owner hooked up a clutchable super charger (a la MadMax) & thats wat it could be for....
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
10-30-2006, 11:47 AM | #7 |
Outlandish Trends - FL
Re: Toggle switch?
I had a toggle switch in mine, but under the dash on the left side of steering wheel. I followed the wires and they went to the heater fan. I ended up replacing the heater controls and now the toggle switch is working for my air compressors as a backup manual on/off feature.
-Bret 67 short-fleet sold! |
10-30-2006, 10:28 PM | #8 |
Re: Toggle switch?
I'll follow the wire next time I get home from college. It really stinks being 180 miles from my truck.
10-30-2006, 10:43 PM | #9 |
Re: Toggle switch?
I had a toggle that was a switch for my a/c. Sucked when you forgot and left it on.
1972 Chevy Cheyenne 20 1979 Chevy Camaro 2007 Chevy Avalanche 2005 Mini Cooper |
10-30-2006, 11:56 PM | #10 |
Re: Toggle switch?
10-31-2006, 12:56 AM | #11 |
Re: Toggle switch?
10-31-2006, 01:39 AM | #12 |
Re: Toggle switch?
if its like mine, okie constant hot to dome light
10-31-2006, 02:01 AM | #13 |
Re: Toggle switch?
look at the airplane cockpit in andy's post... good luck figuring out what all that crap does...
http://67-72chevytrucks.com/vboard/s...d.php?t=214768 |
10-31-2006, 02:10 AM | #14 |
Re: Toggle switch?
mine has a toggle below the key hole.....its for a fan...pretty sure it was added on by the previous owner...
10-31-2006, 07:21 PM | #15 |
Re: Toggle switch?
Might have been put there by PO to make every body who got in the truck to wonder... I wonder what that switch does?
'07 G6 Wife's car '00 Malibu stock, just a parts getter. '99 Blazer LT Loaded, K&N Filter, Pioneer Super Tuner,Viper '88 K1500 Cheyenne, 5.0, stock, bought new '86 Nissan 720 Trash Truck '69 C/10 step side, 307, all original, second owner, in process of restore. The person who says it cannot be done should not interrurt the person doing it. Share your knowledge. It is a way to achieve immortality. Allen- Paintman Wrenchtwister Broompusher |
