Old 10-31-2006, 11:15 PM   #1
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
AC Fan Switch
Hi Guys,
Every time I turn the ignition switch to the "on" position, the fan motor kicks on for the AC. Can the switch be cleaned? Maybe something is stuck in the switch so it can't fully turn off? The AC itself works awesome in it, it'll run you out of the truck. lol
TIA,
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 11-01-2006, 10:00 AM   #2
Bad Karma
Magnificent bastard
Bad Karma's Avatar
Re: AC Fan Switch
The fan is always on, there really is no "totally off" position. When the fan switch is on Low, and the vent controls are turned to Off, the fan will still run at low speed.
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 11-10-2006, 01:15 AM   #3
aggiedave98
Re: AC Fan Switch
that's not really true is it?? on what years?
on my '89 burb i don't think that is the case. I have a 4 speed fan and then the other switch is off, max ac, norm ac, hi-lo ac, heat, vent, defrost. when it's in off, it's off.
aggiedave98 is offline   Reply With Quote
Old 11-14-2006, 07:03 PM   #4
Bad Karma
Magnificent bastard
Bad Karma's Avatar
Re: AC Fan Switch
Mine's a '77. I didn't want to believe it either, but after a quick look at the schematics, that's how it works. Don't know if that changed later on or not, though.
I seem to remember reading something on CK5 about it, something about keeping a small amount of air flowing through the heater core at all times for some reason...
1977 Big Block Burb
Old 11-15-2006, 01:30 AM   #5
jimfulco
Re: AC Fan Switch
I've heard it's one or the other of two reasons. One theory says it's to keep the A/C from freezing up, and the other says it's to make you buy a new truck when the original motor starts making that god-awful screeching noise.
jimfulco is offline   Reply With Quote
Old 11-17-2006, 11:40 AM   #6
aggiedave98
Re: AC Fan Switch
I replaced my front fan blower motor for $16 and it only took about 4 screws and 15 minutes...
