11-11-2006, 05:37 PM | #1 |
Sbc Overhauling 123 Top To Bottom W Pictures And Commentary
69 CHEVY 355 SMALL BLOCK
LETS START WITH THE HEADS stock 882 cast heads press in studs ....start to finish stud towers milled off and tapped for 3/8 studs and push rod guides Z valve springs, comp cams retainers, and positive valve seals. comp cam full roller rockers ,1.5 ratio and 3/8" studs. gm performance valves used lock tight on stud bolts ---- 3 angle valve job. $325.00 Last edited by rage'nrat638; 07-12-2007 at 07:01 AM. |
11-11-2006, 05:40 PM | #2 |
Re: Sbc Overhauling 123 Top To Bottom W Pictures And Commentary
installing new studs and guide plates and 1 coat of paint
comp cam poly locks.. rebagged ready to install on block... Last edited by rage'nrat638; 07-12-2007 at 07:01 AM. |
11-11-2006, 05:42 PM | #3 |
finishing up
11-12-2006, 05:21 PM | #4 |
well lets start to day by removing the oil pan..
notice the 4 bolt mains clean the block head mating surfaces and retap out all mounting holes apply thread sealant to all head bolt holes and bolts preinstall oil pump tube welded into place Last edited by rage'nrat638; 07-12-2007 at 07:01 AM. |
11-12-2006, 05:24 PM | #5 |
after cleaning surfaces...clean out all mounting threaded holes with the tap set..a must for head bolts...
11-12-2006, 05:28 PM | #6 |
some new parts..
arp head bolts arp fuel pump rod lifters cam double roller t-chain felpro gasket set Last edited by rage'nrat638; 07-12-2007 at 07:01 AM. |
11-13-2006, 11:12 AM | #7 |
Great quick 'n dirty overhaul thread. A couple of quick questions:
A couple of comments for your and the watchers feedback and perspective:
11-13-2006, 07:36 PM | #8 | |
the heads i had redone at the mechine shop... the intake gasket surfaces will be cleaned with thinner...as was everything i had rag's stuffed in each cyl hole while cleaning... power flushed each cyl... compressed air dryed.... no threads or animals were hurt or killed during this rebuild MY OIL PAN GOT SHIPPED TO WISC. SHOULD BE HERE TOMMARROW NIGHT NOW...just as well it's raining outside and i can't (won't) sit my prostreet truck out in the rain Last edited by rage'nrat638; 11-13-2006 at 07:39 PM. |
11-14-2006, 09:30 PM | #9 |
ok lets get on with the new oil pan install...
this pan has trap doors inside and a crank scraper... the best thing is it has flange reinforcement Last edited by rage'nrat638; 07-12-2007 at 07:01 AM. |
11-14-2006, 09:34 PM | #10 |
next is 35.00 worth of stainless steel bolts..enough for the complete engine from ace hardware ...SWEET
MY NEW TALL VALVE COVERS... and two stickers to hold it together... Last edited by rage'nrat638; 07-12-2007 at 07:01 AM. |
11-14-2006, 11:15 PM | #11 |
Okay I have one quick question. Is this motor originally a '69 out of your truck. I dont know the difference motor wise between a 2 piece and a 1 piece rear seal block. I'm assuming from yours it is a stock '69 block with a one piece oil pan gasket. Like everyone else that owns a Chevy. I'm having problems getting my '73 motor in my '86 to seal up right at the pan. Will this gasket you've used work on my 2 piece rear seal 350 out of a '73? And it looks like in the picture it has some sort of blue permatex or something or is that just the gasket? You've got me wanting to pull my dang motor and paint and clean up the turd. Thanks for this detailed buildup.
Brandon |
11-15-2006, 12:14 AM | #12 | |
yes its blue sealer just in the four corners...the rest goes on dry.. THE KIT COMES WITH ALL NEW BOLTS AND WASHERS.... |
11-15-2006, 02:41 PM | #13 |
Active Member
Man, that looks great! I love the black on orange
11-15-2006, 03:58 PM | #14 |
On a budget like Fred Sanford
Cool thread! Engine looks awesome. If you don't mind me asking, where did you get the "super duper" oil pan & what did it cost?
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
11-15-2006, 09:09 PM | #15 | |
EBAY ITEM #Item number: 8073851381 http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget |
11-15-2006, 09:23 PM | #16 |
INTAKE INSTALL TIME !!!!!!!
i started by cleaning the mating surface's put thread sealer in the open ended hole's on the heads...for sure the 4 by the carb base that always seem to leak.... i am using the sweet baby blue silicone that match's the baby blue felpeo gaskets throw the rubber end seals away..for the intake valley... put thread sealer on the intake bolt ends and tighten as GM recommends Last edited by rage'nrat638; 07-12-2007 at 07:01 AM. |
11-15-2006, 09:28 PM | #17 |
next we sit the intake into place and installed the bolts as mentioned
i also installed my new ARP fuel pump rod and fuel pump... using the fancy S.S. bolts also installed my high dollar alum water pump...O YEA Last edited by rage'nrat638; 07-12-2007 at 07:01 AM. |
11-15-2006, 07:35 PM | #18 |
SLOW BUT SURE,BUT CLOSER
Cool thread and love those home built small blocks.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... |
11-16-2006, 10:18 AM | #19 |
67-72 Addict!
Lookin' good Mark!. How did you get the carb so clean?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
11-16-2006, 09:30 PM | #20 |
11-16-2006, 09:40 PM | #21 |
well to night i started by filling the engine with oil 10W40 so i can prime the engine on the engine stand..filled thru the dizzy hole on the intake manifold.
i just got my new sbc balancer installation tool..i will install the balancer and use that tool to turn the engine over to adjust my roller rockers... Last edited by rage'nrat638; 07-12-2007 at 07:01 AM. |
11-16-2006, 09:48 PM | #22 |
next we use my home made engine primer tool made from a old points dizzy
now i made some cardboard rail's as you will see...they worked a little, oil still went all over...i must have spent 1 hour priming and rotating the engine to get each rocker to have oil to them...filling each push rod with oil is a big help...before adjusting the rockers Last edited by rage'nrat638; 07-12-2007 at 07:01 AM. |
11-16-2006, 10:00 PM | #23 |
well adjusting the rockers is very easy....
i used my chilton manual to find out which valve's to adjust with each rotation of the crank...the balancer install tool is excellent for turning the engine over to do this....adjust each poly lock untill zero lash and then 1 complete turn and tighten each poly lock Allen set screw... ENGINE ON TOP DEAD CENTER BOTH VALVES CLOSED ON #1 CYL ADJUST INTAKE AND EXHAUST VALVE LISTED IN BOOK.. ROTATE THE CRANK ONE REVOLUTION TO #6 FIRING ORDER ADJUST INTAKE AND EXHAUST VALVES LISTED IN BOOK.. THERE DONE... Last edited by rage'nrat638; 07-12-2007 at 07:01 AM. |
11-18-2006, 11:29 PM | #24 |
Dang that's looking good! Can't wait to get my new 383 fired up. Need headers and exhaust.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
11-19-2006, 10:45 PM | #25 |
well i am getting a ton of views on this post..but nobody's saying anything
should i keep posting pictures.. as planned or call it a day... it takes a lot of time to take all these pictures and post them..are they doing any good? mark |
