Old 11-12-2006, 11:09 AM   #1
llama
Question under dash install
Starting to put the cab back together. Had a video of taking it apart but was lost in the move. What order should you put thing back. Steering column, wiring, ac and heating, duct work, Everything under there. What order to save some time. Thanks for any help
llama is offline   Reply With Quote
Old 11-12-2006, 01:10 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: under dash install
I would start under the dash then wire it then add the steering it will just be in the way until you can drive it. Inless you have to move it around while you work on it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-12-2006, 02:07 PM   #3
70GMCer
70GMCer's Avatar
Better put the dash pad in 1st. Those speed nuts for the pad are hidden after other things are installed....then glove box, then heater assembly, brake and clutch pedal assembly, wiring harness, dash panel/gauges, then column. That was the order I put things back....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-12-2006, 04:44 PM   #4
ghetto_superman
ghetto_superman's Avatar
except id do the glove box after the heater assy. i just took out my heater assy. and its lots easier to get to the heater box bolts with the glovebox out. my .02
ghetto_superman is offline   Reply With Quote
