11-13-2006, 09:07 PM | #1 |
Headers on lowered truck
Mk, so right now I've got the Hooker Super Comp headers and they sit way too low for a lowered truck. I'm hoping to make the frame lay on the ground and curious what other people with lowered trucks are running for headers to clear the frame yet remain long tube if possible because I like being able to dragrace it w/ straight pipes
11-13-2006, 09:28 PM | #2 |
Re: Headers on lowered truck
Block hugger headers would work. Look up Patriot Headers.com.
11-13-2006, 11:33 PM | #3 |
he wants to stay long.. You might have to get a kit and weld your own together if you want to stay level with the frame.. I have heard that 3/4 chevelle headers work also, but they point down.. You might want to do some searching on the internet and talk to some header makers.. They might be able to help you better..
11-14-2006, 07:19 AM | #4 |
65 suburban vortec 5.3 bagged
i think making your own or block huggers are your only choises i looked and tried a bunch of different headders and they didnt make enough clearance good luck
11-14-2006, 01:28 PM | #5 |
How's about running block huggers with dumptubes?
11-14-2006, 04:57 PM | #6 |
11-14-2006, 05:26 PM | #7 |
I have the Hooker Super Comps & they clear, my crossmember/lower a-arms are lower then they are.
11-14-2006, 07:12 PM | #8 |
The LuvShack Garage
Not sure if they would fit your application, but mine are mid length, and
were 4.5 inches higher than the long tubes that I removed, hope that it helps, pm me if you need part #'s, mine are for a 67-72 4wd application.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 11-14-2006 at 07:14 PM. |
11-14-2006, 08:15 PM | #9 |
They came on the truck when I bought them, the last time I was looking around under there I thought they went into the collectors back behind the motor which made me think thery were full lenth, shortys hit the collectors along side the motor don't they?
11-14-2006, 08:31 PM | #10 |
Sounds like you might have the mid length headers. I may end up getting them, but I'm debating seeing if I can find a way 2 cut and bend mine up so that they will sit up in the frame cuz I hate getting rid of these. It just sounds so dang amazing with them on the 350
11-23-2006, 10:41 AM | #11 |
To Left Coast,
I am working on a 62 fleetside and am looking to lay frame as well, it has been quite the process with the air bags power steering conversion and whole front crossmember conversion...I looked into headers for the 350 I am running in it(it will soon be installed) and I will be running hedman 68600, I have great luck with them in the past on my chevelles and my 68 camaro...hope this helps...by the way they are intermediate length but they flow great....how are lowering your truck? I am looking for some tips on how to do this thing right the first time...thanks and good luck |
11-23-2006, 11:33 AM | #12 |
Check this guy out on eBay. He might have what your looking for. I've not used his headers but was considering it. These are stainless but he has others that are ceramic coated.
http://cgi.ebay.com/ebaymotors/CHEVY...mZ260053232697 Last edited by kdevore2; 11-23-2006 at 11:35 AM. |
11-24-2006, 09:24 PM | #13 |
UCA63
Basic Air suspension in this months HOT ROD mag
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
11-24-2006, 09:51 PM | #14 |
Chevy Truck Addict
I'm going to be running a mid-length Edelbrock on my truck. I have test fit them with the engine still on the frame and they dump out at the top of the frame rail about even with the back of the block. Photos of how they fit are on the thread below:
http://67-72chevytrucks.com/vboard/s...=215994&page=2
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
11-30-2006, 01:38 AM | #15 |
someday it will be done!
I say modify your existing headers if you're otherwise happy with them.
Get yourself a few 180 deg. mandrel bends and go to town! check out this website too,I learned a lot from it. www.headersbyed.com
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics Last edited by Rollie396; 11-30-2006 at 01:38 AM. |
11-30-2006, 02:00 AM | #16 | |
11-30-2006, 03:54 AM | #17 |
wow that is an ambitious project!I wonder if you'd have to tunnel the cab floor too?How about driveline angles?
If you do go that route,make sure to post lots of pics for us!
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
11-30-2006, 01:08 PM | #18 |
Ya, I'm thinking I may have to mess with the floor a little bit, but that hsouldn't be bad. It is pretty high as it is and it's the two piece driveshaft which helps with raising the transmission as well as lowering the truck so much. It's quite ambitious, but I'm planning on pulling the motor to do body work anyways, so it's just the little extra's such as raising the firewall which will be different.
11-30-2006, 02:29 PM | #19 |
SIR
....IMHO...why would you want to "lay-frame" in the first place? if something goes wrong with your system..YOUR SCREWED! granted it looks very cool but unless it's a "trailer-queen" I would keep "driveabaility" in mind as for your headers... if you have the time to completely re-fabricate your floors and firewall I would save the time and money and have a pro custom build your headers that way you can be driveing your truck in less than a week rather than however long it would take to fab up a new floor and firewall..just a thought...
66long low fleet http://community.webshots.com/user/LVNR66 Last edited by SIR; 12-08-2006 at 02:54 PM. |
11-30-2006, 06:31 PM | #20 | |
Nice lookin frame, really great powdercoating setup and headers. Last edited by leftcoast66; 11-30-2006 at 06:34 PM. Reason: add a thought |
11-30-2006, 11:24 PM | #21 |
SIR
...very cool great ambition!! I like that "can-do" attitude....keep us posted on your progress,
and what you see under my truck is many hours of clean up wire brushing and sand blasting ...and it's all paint, I don't have that kind of money ether..
66long low fleet http://community.webshots.com/user/LVNR66 |
