Old 11-15-2006, 04:32 PM   #1
greenmtnboy
greenmtnboy's Avatar
Question 3 speed manual trans ID help
Can anyone tell me the interchangeability and tips to ID the 3 speed
NON-synchronized and 3 speed synchro transmisions. I have a '63 c10 with a 3 on the tree non synchro and am thinking about looking for a trany to swap.
Thanks.
greenmtnboy is offline   Reply With Quote
Old 11-16-2006, 12:04 PM   #2
60-66 Nut
Professional Beer Tester
Re: 3 speed manual trans ID help
GMB, the non-synchronized 3 speeds were used in most all 55-66 trucks and even some of the 67-68 trucks too. There were several syncronized 3 speeds used in GM trucks, Saginaw 66-87, Muncie Heavy Duty 69-76, and even a Tremac(yes like Ford) from 76-81. The Saginaw is a good transmission and is probably the most common you will find, but any of them should work. The main difference is they are all longer than the old non-syncro 3 speed, so you will have to either cut your drive shaft or find another one. Also, the Saginaw has a fine spline output shaft like a TH350, so you will need the yoke to go with the trans. They should all have the same bolt pattern to the bell housing and the same input shaft, but the front bearing retainer is bigger on the newer(68 up or so) transmissions, so the hole in the bell housing will need to be machined out or the retainer cut down. Or you could always replace the bell housing with a 68-72 housing. Hope this helps.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
