11-15-2006, 06:42 PM | #1 |
Dealer installed 4-way flashers
Well, while looking in a box of parts that was with the truck, I found a flarestat 4 way flasher, exactly like this one on e-bay, even has the flasher thingy itself
Anyways, I was not going to incorporate it into the new wiring harness b/c I thought it was not a factory thing, but now I would like to use it since I found out it was a delaer thing. What would be the best way to incorporate it into the painless harness? How was it installed originally (steering column connector?) any help would be appreciated |
11-15-2006, 07:41 PM | #2 |
Hollister, CA.
Re: Dealer installed 4-way flashers
Well, that 4-way should have a power lead going in and 4 leads going out....correct ??
You want to connect to the (+) leads going to each corner....after the factory turn-signal switch. That switch has a light in the knob...not sure if its self-grounding or theres a wire for that as well Then the flasher it self would need constant power from the fuse block... Hope this helps... John
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
11-16-2006, 01:50 PM | #3 |
Professional Beer Tester
I have two of those(one is in my 65 C80), and both have connectors that plug between the signal switch and the harness. I would think the painless harness should have the correct connector for the signal switch, that is, provided your four-way switch has the connectors on it like mine do.
60-66 Nut
60 Ford F100 Custom Cab 61 Apache Short Fleetside 64 C10 Short Stepside 65 C80 409 V8 5spd(X-Firetruck) 83 GMC 350 Olds Diesel 85 GMC Short Bed 86 GMC Short Bed 90 GMC R3500 Crew Cab 92 GMC 1500 |
11-17-2006, 12:56 AM | #4 | |
Hollister, CA.
Painless usually supplies both the long and short GM connector, for people who run different columns. John
