NOT REALLY BANNED!
![]() Join Date: Jul 2004
TH350 Swap?
What all do I need to swap from a 3speed manual to a 3speed automatic? IIRC, both of the transmissions are the same arent they?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
Designated A-hole!
Re: TH350 Swap?
You'll need an auto tranny crossmember and a column out of an auto truck (unless you wanna floor shift the auto). You'll also need a radiator with a tranny cooler in it. That's not a complete list (since I haven't actually had to do this swap) but it's what I can think of off the top of my head.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Re: TH350 Swap?
auto trans crossmember and trans mount
auto column with linkage (column to trans) Billsbowtie has those for sale kickdown bracket for intake/carb and kick down cable vacuum modulator line(steel) , hose and vacuum port nipple trans cooler (aftermarket) or radiator with built in cooler but I recommend the aftermarket trans cooler auto trans flex plate and bolts trans dust shield recommend new U-Joints while drive shaft is out Plus the auto trans bell housing bolts that should be it |
NOT REALLY BANNED!
Re: TH350 Swap?
Thanks for the help guys, but forget all that. I'll have to find a 4speed.
Re: TH350 Swap?
Yea...it may seem like alot of work, but really....there isn't much to change. The biggest PITA for me was cutting out that danged crossmember that couldn't be any closer to the cab. I'm only into my auto trans swap about $400, minus the $6 quarts of trickshift.
'71 SNB, 406sbc, TH350 w/ Transpak & Starshifter, 12bolt w/ 3.73s, 2" Early Classic front coils, 2.5" Flowmaster Super 40's
