Old 11-16-2006, 12:57 PM   #1
james48
Talking 2wd conversion
I just purchased a 72 blazer 4x4 and want to convert to a 2wd I already have the front suspension, the rear trailing arms and crossmember, rear axle and coil springs how and where can I get the right measurments for the placement of the rear trailing arm crossmember any help would be greatfull
thanks
james48 is offline   Reply With Quote
Old 11-16-2006, 01:35 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: 2wd conversion
http://www.chuckschevytruckpages.com/framespecs.html
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-16-2006, 08:25 PM   #3
james48
Re: 2wd conversion
thanks for the tip.
Old 11-16-2006, 08:56 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: 2wd conversion
From West TN
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-16-2006, 10:32 PM   #5
texas69truck
Re: 2wd conversion
Edited by Moderator
texas69truck is offline   Reply With Quote
Old 11-16-2006, 11:13 PM   #6
bigbluthng
bigbluthng's Avatar
Re: 2wd conversion
the way idid it was to mount the trailing arms to the axle, then center the axle in the wheel opening. i mounted the trailing arm crossmember and measured to make sure everything was sqyare to the frame, then i drilled the holes for the crossmember and mounted it with grade 8 bolts. the biggest challenge was the coil springs, since the 2wd frame flares out over the axle as opposed to the 4wd frame which is pretty much paralell all the way back. if ytou have some fab skills you can make a mount to support the coil springs
if you got anymore questions feel free to email me. i am gonna remove the trailing arms in favor of a 4 link since i decided to go lower.
bigbluthng is offline   Reply With Quote
Old 11-17-2006, 09:36 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 2wd conversion
Is there are reason to convert the rear to trailing arms and coil rather than leaving the leaf spring and flipping them under the axle?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-17-2006, 10:25 AM   #8
Chris27
Blazerless
Chris27's Avatar
Re: 2wd conversion
Trailing arms and coils ride and handle alot better than leafs. The trailing arm suspension in the trucks is the same basic suspension modern nascar stock cars use! It's rumored GM put this suspension in the trucks so it would be legal for nascar use.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD
69' Beaumont 388/700R4 11.70@116
77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad.
Chris27 is offline   Reply With Quote
Old 11-17-2006, 07:26 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 2wd conversion
Originally Posted by Chris27 View Post
Trailing arms and coils ride and handle a lot better than leafs. .....
Ok, I don't really agree with that, but lets not argue about ride and handle characteristics.
Beyond that is there a reason to hassle with a major conversion rather than just flipping the springs and being done with it?
Articles-
"Refining Sierra"
Old 11-17-2006, 07:29 PM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: 2wd conversion
It's easier to flip & bag the springs you got, than to swap it all out, jmho
Old 11-17-2006, 08:49 PM   #11
james48
Re: 2wd conversion
I'm getting back more feedback than I thoughtand I'm truely thankful, even though I decided on using the trailing arms I'm just being different
Old 11-18-2006, 04:50 PM   #12
james48
Re: 2wd conversion
I just located a 68 shortbed frame I know that it's a little longer than a blazer frame but could I just swap out the body or is it more of a headache case I'm also thinking the body mounts being in a different location than the blazer, And how much more would the frame stick out the back?
Old 11-18-2006, 05:07 PM   #13
smbrouss70
smbrouss70's Avatar
Re: 2wd conversion
You would have to shorten the wheelbase by 11" IIRC. Then you have to figure out body mounts and such. I'm getting ready to convert a 4x4 frame over to 2wd, to me it just seems easier to use the original blazer frame.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 11-18-2006, 05:19 PM   #14
krue
Designated A-hole!
krue's Avatar
Re: 2wd conversion
Take a lot of pics and write a FAQ for us.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
