11-17-2006, 10:44 PM | #1 |
67-72 Crossmember swap/Big Block frame mounts
Hey People,
I am swapping an '88 Sub 3/4 ton front crossmember into a '69 factory Big Block truck. I am concerned about the shape of the late crossmember being different where the engine frame mounts bolts to it. I am either going to use the '72 only frame mount, or a '73 up frame mount. For those of you who have done it, which engine frame mounts are best to use, and does the Engine/Trans. mount correlation stay the same? Thanks, Tim |
11-18-2006, 02:16 PM | #2 |
Re: 67-72 Crossmember swap/Big Block frame mounts
I had a question that was similiar to yours, but not exactly....here it is....http://67-72chevytrucks.com/vboard/s...d.php?t=216573 ...I was pretty sure I would get more responses than this, but maybe everybody just uses the original mounts from the 67-72...
11-18-2006, 03:02 PM | #3 |
Location: vacaville ca, because it as far from indy as i can be
11-22-2006, 11:33 PM | #4 |
Thanks for the input guys
11-23-2006, 12:23 AM | #5 |
I swapped a 86 front suspension complete with the crossmember into my 69. I tried to use the 86 frame stands and they were too tall. like the frame wasn't as tall as the 86.
I had a bunch of different brackets and the 67-72 will work fine with a couple of holes drilled. I did not want to use the rare 72 bb set i had, so i used a set off on a 76 I stripped. Again only a couple of holes needed to be drilled. i did use the brace from the 86 that lays on top of the bottomframe rail. The only real reason to swap crossmembers to me is that the oil pan is easier to remove. I would never do it again. i would swap all the components and leave the orginal crossmember on the truck. By using the 73-79 style brackets you can use the clam shell mounts on a big block. Last edited by qksilver; 11-23-2006 at 09:18 PM. |
11-23-2006, 01:27 AM | #6 |
"By using the 73-79 style brackets you can use the clam shell mounts on a big block."
that is one of the most important parts. i see lots of people swap in high hp bbc's and use the stock motor mounts!!! its like cutting the rope youre hanging from!!! not that a motor mount is going to get you kiiled but it just doesnt make sence. hell, my buddy is constantly trashing urithanes with a mild sbc. |
