Old 11-18-2006, 11:40 PM   #1
frankyrealtor
Air Ride Troubles>
Hi, I just plumbed the front and when the compressor is running the Left side air's up all by its self. Any info helpful. I have every thing wired right and valves going the right way .and then the compressor never turns of i have to take the ground off.I have all kthe diagrams from everywere. Does any body have pics or info.
frankyrealtor is offline   Reply With Quote
Old 11-19-2006, 12:57 AM   #2
LuckyHG
LuckyHG's Avatar
Re: Air Ride Troubles>
Sounds like your valves could be stuck open on that side. Double check the wiring on the valves. The compressor probably isnt shutting off because its filling the bag too.
Are they brand new valves or used?
71' 2wd sub <------parts donations accepted
99' 4wd big block sub
92' K2500 ext cab Lb
95' S-10 sfbd, hydro's, etc.
02' Ram bagged etc.
83' International School bus...flat black with alot of room
www.Homegrowncustoms.com
LuckyHG is offline   Reply With Quote
Old 11-19-2006, 01:12 AM   #3
jimmydean
jimmydean's Avatar
Do you have a tank gauge? If so, does it read past the shut off pressure of your pressure switch? What pressure switch are you running?
I agree that it sounds like the valve is either stuck open or is "on". If the compressor is not turning off, then it sounds like your pressure switch is bad.
jimmydean is offline   Reply With Quote
Old 11-19-2006, 09:34 AM   #4
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
How do you have your valves set up? Sounds like you may have one backwards, or like said one may be stuck open. Are you running a pressure switch? What psi?
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 11-19-2006, 09:27 PM   #5
frankyrealtor
Thanks for the replys . The switch is 200psi. on 165 off /. It runs all the time i am thinkg about getting a, lower one. I will take pics but it looks like crap right now. But i dont let it run till if gets 200 psi . it is a little tank. 8 port. I dont really know what the he## im doing . Wiring is a pain for me. It is just a frame right now and i think i have it hard wired to the batt and thats why it is not turning off. Its always getting power . does that make sense.???
Old 11-19-2006, 11:33 PM   #6
jimmydean
jimmydean's Avatar
The power goes to the switch, not the compressor. Run the + to one side of the pressure switch, then the other side of the switch goes to the compressor. That way, when the pressure in the tank is low, the switch will "close" and turn the compressor on until the tank is full.
It might also be a good idea to run a toggle switch between the battery and the pressure switch in case there is a slow leak so the compressor isn't running when the truck is in the driveway.
Old 11-20-2006, 10:00 AM   #7
frankyrealtor
Great thanks for the help. I will Try that
Old 11-20-2006, 12:14 PM   #8
craig@ridetech.com
Formerly LSC71
It will also help to know which compressor you are using and with what size tank. If your pump isn't capable of putting out 200psi then that will be a problem as well as if it isn't able to fill the size of tank you have to 200psi. But as far as your valve goes, you definitely have a problem with that side either sticking open or it is getting constant power and staying open.
craig@ridetech.com is offline   Reply With Quote
Old 11-20-2006, 02:33 PM   #9
jimmydean
jimmydean's Avatar
Good point. I didn't even think of a compressor not being able to reach the level of pressure to shut off. I ran a 140-160 switch because my bags are rated at 160 and my gauges only go to 150. I think I might bump the switch up to 200 if the compressor is running a lot to keep the tank full. But I have a feeling I will hardly ever be running my bags (if ever) at 150 psi.
Old 11-20-2006, 10:07 PM   #10
67Fleet
67Fleet's Avatar
Yeah, I run my fronts between 70-80 psi and the rears at around 20-30psi. I can lock the control arms at around 100psi or less. It doesn't take as much as you'd think.
-Bret
