11-21-2006, 05:58 PM | #1 |
Carb. Problem
I have an Edelbrock 600 cfm electric choke carb. that i bought brand new a few years ago and for the last 6-8 months it has been giving me problems. Every few months it will start leaking gas out of the left side at the bottom underneath the throttle linkage. I have already replaced the base gasket about 3 or 4 times. Also, everytime it leaks it fouls out the sparkplugs, so I have had to replace the sparkplugs about 3 or 4 times. The carb. is not tightened down too much and it is not too loose either. It doesn't appear that the carb. or intake is warped either. I am seriously tired of having to replace the spark plugs because it adds up over time. The motor is a Chevy 350 smallblock and the intake is an Edelbrock as well. Does anyone have a clue as to why the carb. keeps leaking gas from the base? Thanks in advance.
11-21-2006, 06:35 PM | #2 |
Re: Carb. Problem
I would pull the top off and see if the carb has junk in the bowls. Sounds like the floats are not stopping the flow of gas and it is just overflowing. Could be a vent problem or a evap canister bad. You didn't say what year truck as some vent through cap and some vent through evap canister.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
11-21-2006, 07:01 PM | #3 |
Re: Carb. Problem
Check your fuel pressure. Eddy's like about 5 PSI. Also, check your floats.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
11-21-2006, 07:57 PM | #4 |
Re: Carb. Problem
It's not the original motor. I believe it originally had an inline-6 in it. I thought about the floats maybe being the problem but haven't had a chance to actually check them out. If it is the floats then what should I do, just replace them?
