Old 11-21-2006, 06:58 PM   #1
diggertodd
diggertodd
diggertodd's Avatar
ash tray removal problems
I am so afraid I'm going to look stupid asking this one...
Four fasteners removed from Ash tray housing
2 up under the slide opening and 2 outer fasteners on the lower side
- it will not budge - are ther spot welds???
- now is your formal invitation to make me look stupid
diggertodd is offline   Reply With Quote
Old 11-21-2006, 07:14 PM   #2
qksilver
Re: ash tray removal problems
Not me..................
qksilver is offline   Reply With Quote
Old 11-21-2006, 07:59 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Talk about dumb... I just took mine out a couple of weeks ago and I'll be damned if I can remember. I thought there was just the four screws. Does the radio brace fasten to the back of it? Unless someone else answers I will check mine out in the morning....
LockDoc
I couldn't stand it, I had to go look. There are four screws, two at the top of the ashtray opening and two above the heater control behind the dash.... I don't know if you can get to the ones behind the dash without taking the heater control out or not. Nothing else that fastened to mine.
LockDoc
Leon
Old 11-21-2006, 08:04 PM   #4
Chevyman680063
Chevyman680063's Avatar
I don't think there are any spot welds because I removed mine back during the first part of the year. I can't remember how exactly I removed it but there were no spot welds. Sorry I couldn't be of more help.
Chevyman680063 is offline   Reply With Quote
Old 11-21-2006, 08:21 PM   #5
diggertodd
diggertodd
diggertodd's Avatar
The answer is.... drum roll ....
I slightly separated the ash tray from the dash panel until it showed two spot welds right beside the upper screw holes - figure that one out - masking taped the dash off and hit it with a die grinder - fell out...
It was factory welds too, the original paint was up in the fitment of each.
Old 11-21-2006, 08:44 PM   #6
LockDoc
LockDoc's Avatar
I've never seen one put in that way... So much to learn, so little time...
LockDoc
Leon
Old 11-21-2006, 10:02 PM   #7
Green Machine
Green Machine's Avatar
What year is your truck?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 11-22-2006, 07:10 AM   #8
Aarons72s
Ah yes I have seen a few spot welded. I found them on a janesville truck. pita to remove. I think I also had to do it on a couple of st louis trucks to. Is yours an a/c truck? All that I have found spot welded were a/c trucks. Hope this helps.
Aarons72s is offline   Reply With Quote
Old 11-22-2006, 10:24 AM   #9
diggertodd
diggertodd
diggertodd's Avatar
yep, 1970 A/C truck - now with cracks in the dash paint from me trying to animal-out a frakin ash tray...
Old 11-22-2006, 01:01 PM   #10
396muncie
396muncie's Avatar
I had a 70 non-ac with the spot welds. Maybe it's a 1970 thing?!?!
396muncie is offline   Reply With Quote
Old 11-22-2006, 05:00 PM   #11
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
FYI....My 71 non-ac cab did not have any welds. Just the 4 screws
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 11-22-2006, 10:06 PM   #12
BubbaGreen
...My 71 non-ac cab has the ash tray bracket spot welded in...
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 11-22-2006, 10:13 PM   #13
al's71gmc
4 eyed fever
al's71gmc's Avatar
My 71 non/ac is spot welded, but i had a 71 non a/c that wasn't, a 70 with a/c that was not, and a 72 non a/c that wasn't. Maybe the assembly plant made the call?
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 11-23-2006, 08:57 AM   #14
llama
71 air cab spot welded
llama is offline   Reply With Quote
Old 11-23-2006, 11:08 AM   #15
Aarons72s
Ok so how about you list what plants the ones that came spot welded.
72 stlouis a/c- welded
71 janesville a/c- welded
72 flint non a/c- screwed
Lets here yours.
Old 11-23-2006, 11:22 AM   #16
Draggn66
Draggn66's Avatar
Ok my non-air 71 was made in Oshawa.
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
