Old 11-25-2006, 07:12 AM   #1
GM72K10
Next!
GM72K10's Avatar
Govt. Surplus Auction, M1008, any one buy one this way?
Hey,
Any one here ever buy anything at government surplus auctions, especially the M1008, M1009, or M1028 4x4s? Any problem removing from depot? Title? Loading? As for the vehicles, hard to swap from 24V to 12V? SHOULD you swap from 24V to 12V? Any one convert one of these rigs to a 5.7? Is the paint on these things really hazardous to remove? thanks for any info.
GM
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 11-25-2006, 10:30 AM   #2
msgross
msgross's Avatar
Re: Govt. Surplus Auction, M1008, any one buy one this way?
Where are you located? I noticed that Mechanisburg was selling a lot of three blazers on their website. I know that the 1 ton pickup are geared very very low and have lockers in the rear, not sure on the front. You will usually find that all military vehicles have low miles but they sit around running a lot. I am sure that the paint is a PITA though. As for hazardous I would have to ask some buddies at work. All Army vehicles are coated with CARC paint (Chemical Agent Resitant Coating). I wouldn't be to scared but would research and buy a respirator if working on the paint. Here is a website I found for you... This relates to Gulf War Syndrom...
http://www.gulflink.osd.mil/carc_pai...ii_s03.htm#iii
Dry CARC poses no known health threat unless disturbed by sanding, grinding, extreme heat, or other conditions that could produce CARC dust, fumes, or vapors. Welding or cutting CARC painted surfaces results in the airborne release of HDI, carbon monoxide, and other toxic materials.[
msgross is offline   Reply With Quote
Old 11-25-2006, 11:24 AM   #3
GM72K10
Next!
GM72K10's Avatar
Yep, looking at Mechanicsburg and Aberdeen. Mainly want to know how hard it is to get a title for one and if anyone has bought one directly at the surplus sales. Thanks
86 K30 CUCV M1028A1
Old 11-25-2006, 04:42 PM   #4
Dean
Dean's Avatar
I've looked at several but the complete package for the 1 ton wasn't completely what I was looking for. They all did appear to be pretty rust free. The ones I looked at had 4.56 gear with locker in back, only had the NP208 tranfer case and the not so hot diesel. Nothing you couldn't switch over if you didn't like.
Dean is offline   Reply With Quote
Old 11-25-2006, 06:21 PM   #5
Southedisto
River life......
Southedisto's Avatar
Ive bought one, easy to do. Bid, pay, schedule a pick up, and pick it up. Some sites will help load, some wont. You need to call before you bid, some sites are only available one day weekly/every two months. Once you pay, you will get an invoice on your account, print it and you may need to fax it to the site manager, depending on the site.
The one that I bought ran and drove, I drove it over 200 miles the day after I bought it. They have 6.2, th400,np208 (1028s have the 205) 4.56s-14 bolt/dana60 axles. The blazers have 10 bolts with 308s. Only the starting system is 24v, everything else is 12volt. They are great trucks, but the prices have gone up over the last few months.
Vehicle registration, well thats a different beast all together. They will issue a sf-97 form, you can use this to register it in your state. Pay attention and make sure that the one you bid on has the forms needed. Depending on the state the paperwork is needed to get a title. Now NC has local inspectors that can come by and sign off on the vehicle and you can receive a title with their help. Anyway, hope this helps. If you have anymore specific questions, feel free to pm me.
Southedisto is offline   Reply With Quote
Old 11-25-2006, 06:50 PM   #6
j hannah
comfortably numb
j hannah's Avatar
ive converted a couple of old deuce an a halfs into fire trucks, if i were you i would plan on blasting the paint off. probably too many brush painted coats to sand. i dont think it's toxic
j hannah is offline   Reply With Quote
Old 11-25-2006, 07:50 PM   #7
msgross
msgross's Avatar
If you run into any group deals (ie lot of two or three) trucks or blazers let me know and I may go in with ya. I have no need (neither does the wife!) for three blazers in the yard! But one for parts is another story.
Old 11-25-2006, 08:03 PM   #8
Prerunner1982
Prerunner1982's Avatar
Not trying to run you off this site by any means, but a great site for Military vehicle information is www.steelsoldiers.com Do a search for SF 97 and you will find ALOT of info regarding registration.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 11-25-2006, 09:18 PM   #9
GM72K10
Next!
GM72K10's Avatar
thanks for all the replies. Did register on GL to bid on a M1008. Checked out the steelsoldiers website also. Really looking for a parts truck to go with my 86 c30, another 2 into 1 deal if you get my drift. An M1008 or M1028 with a bad engine seems the perfect fit. Also have my eye on an 88 K30 with a bad engine. I'll let you all know what I find.
86 K30 CUCV M1028A1
Old 11-25-2006, 09:42 PM   #10
msgross
msgross's Avatar
Those trucks aren't used very hard. Those are all national guard trucks that sit sround most of the year (which isn't that good either). It would be a good investment or start for a mean off road rig. Good Luck!
Old 12-03-2006, 09:37 AM   #11
GM72K10
Next!
GM72K10's Avatar
Got outbid. The M1028 truck went for $1525.00 , someone got a good deal.Checked out an 88 K30 that was the newer style, needed a trans and transfer cas, steering column and has an enclosed plumber's service body on it. Oh well.
86 K30 CUCV M1028A1
Old 12-03-2006, 06:08 PM   #12
84 400
Sb 400 club
84 400's Avatar
too bad man i love those and want one too but no space right now. i did buy an m882 off the us go for my first vehical. for those who don't know that is the 1977 dodge powerwagon rated at 1 1/4 ton. great tuff truck with 49 thousand orignal miles on it. i should have kept it but the wiring was driving me nuts and the t cas was messed up. Also that truck had a bad exhaust valve on it because it sat running alot. even still a nice soldid truck. good luck on the hunt
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
