A guy with a truck
67-72 bagged exhaust
Looking at this, it seems that there will not be much room to route pipes. What are you guys doing? Ideas? Pics?
Thanks -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Re: 67-72 bagged exhaust
Not sure what you're looking at, but I plan to go with a mid-length header and custom tubes and dump my exhaust just after the trans (sort of muscle car style). Just a 45 degree end out of the muffler and call it good.
A guy with a truck
Man, that is going to be LOUD. I want to get it as far out the back as possible.
I am doing shorty headers, and 3 inch all the way out... i put in a tubular crossmember which will give me some room to run the exhaust through, but i also put in the under bed gas tank which wil make it hard to run the pipes out the back. If i can find some mandrel bent 3 inch tubing i will piece it together and then pull it out and tig weld it. If i can get my motor back in soon, I will get some pics of the exhaust. if i don't and any one else has pics i would also love to see them. could save me allot of time.
///Relaxed Atmosphere
I have soempics of the stainless exhaust htat was done on the blue truck that I help put together that was completed backin 2005. Here are the pics I have have at work that show the block hugger headers. Ehaust was 2.5" stainless steel tubing with st/stl Borla mufflers.
Jeff
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
#6 | |
My truck is running ghetto straight pipes and cherry bombs now, so I doubt it could get much louder. |
Outlandish Trends - FL
That looks like Porterbuilt's dropmember in that truck.....
I'm working on the same problems w/ exhaust right now. I'll most likely be going with the ECE drop x-member and will run the pipes through that and then dump them right in front of the rear end. The currently run under the x-member and I have been dragging the snot out of them. I've got a brand spankin new set of Sanderson jet-coated blockhugger headers waiting to go in but I need to get some other things worked out first.
-Bret 67 short-fleet sold! |
Thats a Jim Meyer front end. Very pricey. I looked in to it before I found Nathens Dropmember. That crossmember requires you change everything on your front suspension.
soon to be bagged64sub
I will be using shorty headers from a camaro and dumping it right behind the cab. Before I took it apart for the Z, I had the stock center dump manifolds with a 90 from Autozone and a piece of pipe and dumped it just behind the cab. I made it myself and it worked fine. Pretty cheap too.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
im not bagged but it's all above the frame
![]() yea i have a little oil under there ![]() |
Damian that is how my 72 sub's exhaust is done.
Here are some pics of the blue trucks exhaust: Jeff
WOW, that is super clean. Does your bed have a step in it?
Build Thread |
yes the bed does have a stepp notch in it.
Here's some pics of the exhaust on Dino's 66. It's dual 2.5" fabricated exhaust (180 mandrels cut and TIG welded together) into a 4" Flowmaster 'Super Comp' muffler and turned down and out behind the cab. It's loud... but cool!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#15 |
Señor Member
Mine is a 6-banger, so only one exhaust, but you could repeat on passenger side for duals.
I routed my head pipe to the outside of the frame rail just as quickly as possible behind the front wheel (where the frame comes up at an angle to the front xmember). Once outside the frame, it's pretty much a straight shot all the way back to in front of the rear wheels. The rocker hides everything (my muffler is under the cab, behind the rocker because there's not much place after the cab for a muffler on a stock frame stepside. Since going to the fabricated back half, I'll be able to put as big a muffler as I'd ever want just outside the frame rail either in front of or behind the axle.
#16 |
Señor Member
Oh, mine currently dumps like the last pic in Porterbuilt's post just above.
#17 |
Anyone with bags have their exhaust run all the way back behind the rear wheels?
Build Thread |
#18 |
Señor Member
Possibly, but the problem is that... for a standard bag setup with CPP notch, the axle bottoms out on the notch, which leaves less than 2" of clearance between the axle and the bed floor. So to run all the way to the back, you'd be laying on the exhaust instead of the axle.
#19 |
1969 Chevy C-10 350/700r4 Last edited by el curioso; 12-05-2006 at 01:52 PM. |
#20 |
What headers are yall running when the truck is bagged.
#21 |
Straight jacket required
I heard Sanderson C5 full lengths will work on Big Block and bagged.
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." ![]() |
#22 |
either shortys or block huggers
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
#23 |
![]() Join Date: Jun 2006
here's one pic i have of my exhaust were it exits,i'm running block huggers and it runs on the outside of the frame then between the frame and rear tyre's following the frame kickup over the axle.
#24 | ||
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 12-13-2006 at 09:57 PM. Reason: I'm stupid |
#25 |
Señor Member
None whatsoever. 27" tire on an 8" wheel.
