automatic trans swap question and other...
hey finally starting to pull some parts together so dad has decided to convert the 3 speed on the tree to a 350 turbo automatic...i know so far i need a crossmember and a steering column, my question is what years of trucks can i rob a crossmember from and does it have to be a specific 350 trans or are the 2 speed powerglides the same mount? and i guess the steering column needs to be from a turbo350 truck because of the selector marking correct? also what years or vehicles can i rob a steering column from and make it work? linkages? etc....any help would be great guys....or send me in the right direction if there is another thread on here or a website to go to for a step by step kinda deal....ive searched and havent really found much. thanks!
66 Chevy Farm Truck 94 Chevy Ext. Cab 201,000 miles and still going..... 67 RS/SS camaro (in resto) |
#2 | |
![]() Join Date: Sep 2006
Re: automatic trans swap question and other...
I have also rigged up a juntion plug so the turn signals will work. This is also a tilt column. Last edited by Chevy Fleetside; 12-06-2006 at 12:20 PM. |
![]() Join Date: Oct 2006
nice pic fleet side that column shaft looks nice what is it off of ? What are you looking to get for your column? PM me Thanks Sal
http://public.fotki.com/street
I did the swap and used the original x member just welded a plate on it to accomodate the th350 rubber mount. That way it kept the original park brake stuff. Had to shorten the drive shaft. 3 years ago and it works great
My cross member came out of a 67-72 with auto tranny. There are many models you can use, but thr 67-72 is a direct fit, except you will have to drill bolt holes...
Registered.........
Nice set up Fleetside! What year of a van did you get the column out of, any ideas as to what years will work? If Sal isn't interested in the column, I might be - send me a P.M.
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life |
Junior Member
I've been thinking about puting an auto in the wife's '63 and was wondering what to do about the cross member. I have one from a '72, but didn't know what to do about the parking brake.
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
If you cut the original one up and leave a tab you can drill some 3/8" holes and bolt it to the 72 corssmember and slip the bar back in.. I did it in mine but never took pictures. I still can but I have to crawl under the truck to do it. Acually with the engine and tranny out maybe i don't. I will try taking a pictrue tomorow and post them...
