Old 12-06-2006, 05:17 PM   #1
andyt
andyt's Avatar
Raising a 2wd C/10
Hello guys I am starting to fix up my Dad's old truck. It is a '72 C/10 long bed 2wd. What is different about it is it has a 4 cyl turbo diesel from a tractor in it, which is heavier than a BB. I am planning to use the truck to pull my gooseneck trailer to antique tractor pulls.
Right now my plan for the rear is to put a Dana 60 axle in the rear under the trailing arms with the stock coil spring and also a air bag overload.
The front is where I have the problem. I saw these springs http://www.airbagit-store.com/produc...sp%3Fid%3D2205 but wanted to know if anyone had ever used them.
I am just wanting to raise the truck about 2 inches and have the load capacity to pull the 7000 lbs gooseneck.
Any suggestions or comments are welcome.
Andyt
'72 Custom Deluxe C-10 Allis Chamlers 4 cyl. Turbo Diesel engine, Ford granny low 4 spd. trans.
'91 Dodge D250 Cummins Diesel
Antique Pulling Tractors:
1956 Allis WD45 Diesel
1960 Allis D17 Diesel
196? Allis D21 Diesel
andyt is offline   Reply With Quote
Old 12-06-2006, 11:48 PM   #2
leftcoast66
leftcoast66's Avatar
Re: Raising a 2wd C/10
Andyt
definately if you do anything do not buy from them. Last part I bought from them was 3 inch dropped spindles for my 66 and they sent me disc brake spindles which are totally different and told both my dad and I that all 66 chevy's came w/ disc's and hung up on us and told us if we wanted to send it back it would be a 30 percent restock fee even though it was wrong part. We finally figured them out, they are just POS spindles and aren't for any car. We had to use a file to get them to fit any balljoints and the list of crap goes on and on.
Sparknotes.. Avoid them at all costs.
leftcoast66 is offline   Reply With Quote
Old 12-07-2006, 08:57 AM   #3
andyt
andyt's Avatar
Hey leftcoast66 Thanks for the warning. Does anybody else sell these and will my ideas work? Thanks for the help.
Andyt
Old 12-07-2006, 01:31 PM   #4
leftcoast66
Andyt
Shouldn't be too hard to do. I would look for rancho or a company like that for the front springs. If it's not on their site, I'd just call, odds are they can get a pair of front springs w/ 2 inch lift on them pretty easily, and I would just tell them if they ask for motor it's a BB because of the weight
Old 12-07-2006, 04:40 PM   #5
Prerunner1982
Prerunner1982's Avatar
you could also just use stock BB springs with a 3/4" coils spring spacer...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-08-2006, 09:05 AM   #6
andyt
andyt's Avatar
I found that Rancho makes a 1.5" taller coil spring (#RS6500). This spring is listed for the C-10 and C-20 trucks, Blazers and Subs. I called Rancho, the guy could not tell me if they would work for a BB or not. But he did tell me the spring rate for it, 1050 lbs. I thought this seemed like an awful low number.
Does anyone know what the stock spring rate is for 1/2T and 3/4T?
I got to get this nailed down before Christmas so the wife knows which one to get me.
AndyT
Old 12-08-2006, 04:55 PM   #7
bigbluthng
bigbluthng's Avatar
fabtech suspension sells a 3" lift coil for small and big block trucks 73-87 #ftsc104. i am sure they will work since i had coil springs from a 74 in my 69 longbed when i had it.
bigbluthng is offline   Reply With Quote
