Old 12-08-2006, 01:53 PM   #1
AH619
AH619's Avatar
67 K10 Brake Booster
I Need To Install A Power Brake Booster On My 67 4x4 Fleet.it Has Lots Of Go Power But Terrible Brakes. I Junked A 72 Gmc And Still Habe The Booster.what Problems Will I Get Into If I Install It On My 67? (of Corse The 67 Is Still Drums)
72 2wd lwb cheyenne super youngest son.green/white
72 2wd lwb cheyenne super oldest son.green/white
71 4wd 3/4 cheyenne super frame off manderin
copper / white 4 inch lift. FINALLY DONE / SOLD
72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO
REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR
COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856
AH619 is offline   Reply With Quote
Old 12-08-2006, 08:40 PM   #2
JimKshortstep4x4
Re: 67 K10 Brake Booster
The 72 booster with the mounting brackets and brake rod should work fine on your 67. Just use your distribution valve since you have drum brakes. You will have to change the master cylinder to one for power brakes, though.
Jim
Old 12-08-2006, 08:49 PM   #3
msgross
msgross's Avatar
I'm doing the same thing in my 68 but also changing the front axle to a 75 Dana 44 with discs. Should be an easy bolt in with what you have. Be careful bending the brake lines. I picked up a 1 ton booster so it should put me through the windshield when it stops! (figure of speech)
msgross is offline   Reply With Quote
Old 12-08-2006, 10:06 PM   #4
qksilver
The one ton booster is definitly the deal to make drum brake trucks stop. Get some good brake shoes also ans it will stop pretty good. Disclaimer, you need to do all the normal safety ch4cks when working on brake systems.
One other thing you are going to need to dill another hole about an inch lower on the brake pedal, the power brake hole, other wise the rod to pedal ratio will make it way to sensitive. If in doubt find a P/B equiped truck and measure the distance down for the booster rod hole.
qksilver is offline   Reply With Quote
Old 12-09-2006, 12:07 PM   #5
AH619
AH619's Avatar
thanx guys
