Old 12-11-2006, 02:01 PM   #1
2500HD
2500HD's Avatar
4-6 drop and wheels
My 4-6 drop and disc brake kit from ECE will be here tomorrow. I will be installing on a 67 short bed and my axles are being redrilled and the flange is being turned down.
My wheels are Eagle 211 (torque thrust look a likes). The front are 20x8 with 4.5 backspace and 255/40/20 Toyos. The rears are 20x10 with 5.5 backspace -- I plan to use a 1.25 inch spacer because 5.5 is to much backspace. The rear tires are 295/40/20 and my final backspace will be 4.25.
I am 90% sure 4.5 is the correct backspace for the rear but Eagle only made the 211 20x10 with 5.5 and without cutting down the wheel studs the spacers need to be 1.25. The end result will be 4.25 backspace. the question is are the tires going to rub? Keep in mind I am using the narrower rear end.
2500HD is offline   Reply With Quote
Old 12-11-2006, 06:20 PM   #2
Truword1
Re: 4-6 drop and wheels
Where did you oder you 4 & 6 inche drop? I've been looking and could only find 5 inche drop in the rear.
John
Truword1 is offline   Reply With Quote
Old 12-11-2006, 06:27 PM   #3
Bad71chev406sbc
Bad71chev406sbc's Avatar
John
ECE sells 6" rear coils....I think they are about $115 for a pair. www.earlyclassic.com
'71 SNB, 406sbc, TH350 w/ Transpak & Starshifter, 12bolt w/ 3.73s, 2" Early Classic front coils, 2.5" Flowmaster Super 40's
Bad71chev406sbc is offline   Reply With Quote
Old 12-11-2006, 07:05 PM   #4
SCOTI
SCOTI's Avatar
4.25" shouldn't rub on the inside but might on the outside @ 6" of drop.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-11-2006, 08:50 PM   #5
2500HD
2500HD's Avatar
Early Classic is correct but I think GMS Pauls sells them also.
Scoti
I not affraid of the inside. If I have a problem it will be on the outside. One correction is the rear wheels are 20x9.5 not 20x10. I hope that extra .5 inch saves me. Anyone else with any thoughts?
Old 12-12-2006, 09:20 AM   #6
Inthuwind
Straight jacket required
Inthuwind's Avatar
Pics Pics Pics!!!
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 12-12-2006, 11:38 AM   #7
2500HD
2500HD's Avatar
Before. The after is not done yet. I hope before Christmas.
Old 12-12-2006, 12:42 PM   #8
action
Active Member
action's Avatar
Nice truck
action is offline   Reply With Quote
Old 12-12-2006, 06:50 PM   #9
2500HD
2500HD's Avatar
Originally Posted by action View Post
Nice truck
Its not as nice as the picture makes it look however, it is V8, auto (tired powerglide), power brakes, power steering (I added) and cold factory air.
Old 12-19-2006, 12:23 AM   #10
2500HD
2500HD's Avatar
It is done except the rear spacers are late..... They will be here Wednesday. My measurements tell me my 20x9.5 wheel with 4.25 total backspace and 295/40/20 tire will work great. After 4/6 drop, disc brakes, redrilling the axles, adding a 1.25 sway bar, cross shafts, ball joints, tie rod ends and idler arm I found a bad u joint on the test drive. So I will be replacing u joints in the morning.
Old 12-19-2006, 01:52 AM   #11
SCOTI
SCOTI's Avatar
Post those finished pics when you get it all squared away.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-12-2006, 04:32 PM   #12
XXL
Señor Member
XXL's Avatar
Eagle 211 is available in 5" BS as well (PN# 2119-2983).
XXL is offline   Reply With Quote
Old 12-12-2006, 06:45 PM   #13
2500HD
2500HD's Avatar
Eagles web site lists many backspaces. I originally ordered 20x5 with 5" backspace and 20x9.5 with 5 inch backspace. They sent 20x8 with 4.5 and 20x9.5 with 5.5. I questioned them and they advised they only made the 20x8 with 4.5 and the 20x9.5 with 5.5 regardless of what thier web site said. Many phone calls to Eagle confirmed what the distributor said.
Old 12-19-2006, 11:50 AM   #14
clean71
clean71's Avatar
I'd like to see and hear how that works out as well. I have the same kit for my burb and have been trying to figure out what BS I will need for 20's front and rear.
CPO U.S. Navy(Ret)
1972 GMC Jimmy 4x4 Custom
1972 GMC Jimmy 2x4 Custom
clean71 is offline   Reply With Quote
Old 12-19-2006, 02:16 PM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Can't wait to see the end result...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-20-2006, 06:51 PM   #16
2500HD
2500HD's Avatar
Before and after.
Old 12-20-2006, 07:05 PM   #17
SCOTI
SCOTI's Avatar
What a tease . . .....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-20-2006, 08:43 PM   #18
smbrouss70
smbrouss70's Avatar
C:\Documents and Settings\Owner\My Documents\My Pictures\12_20_2006
It looks like you're trying to link it directly from your hard drive. You either need to upload it to a picture site then link it from there or, go ahead and use the "Manage Attachments" button on the "Reply to Thread" screen to upload it directly to the board.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 12-20-2006, 08:51 PM   #19
2500HD
2500HD's Avatar
Got it..... thanks.
Old 12-20-2006, 08:03 PM   #20
smbrouss70
smbrouss70's Avatar
After--> No Workie!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 12-20-2006, 08:30 PM   #21
2500HD
2500HD's Avatar
I cant get it to work for some reason. Can anyone post if I email to them?
Old 12-20-2006, 09:13 PM   #22
Inthuwind
Inthuwind's Avatar
Nice setup!
Old 12-20-2006, 09:44 PM   #23
smbrouss70
smbrouss70's Avatar
Looks Great!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 12-20-2006, 09:46 PM   #24
RCbowtie69
RCbowtie69's Avatar
sweet , that change the look of your truck, really nice stance
RCbowtie69 is offline   Reply With Quote
Old 12-20-2006, 09:50 PM   #25
powell72
powell72's Avatar
I love it.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
