12-14-2006, 08:10 PM | #1 |
1970 Fleetside bed Question
I am getting ready to start some of the body work on my 70 swb truck. I cannot locate a good metal bed bottom, so I am considering going with a wood bed. Is there anyone that has completed this swap, and what was involved?
1970 Chevy C 10 SWB |
12-14-2006, 08:23 PM | #2 |
member #16
Re: 1970 Fleetside bed Question
You will have to change cross sills and bed front panel. Check here for full info.
http://www.mar-k.com
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
12-14-2006, 08:33 PM | #3 |
I took out the metal bed in my Jimmy and replaced with a wood kit. The hardest part for me was getting the metal out. Ended up buying a pair of electric shears (milwaukee) and eazed the pain somewhat. You could use a angle grinder, buy lots and lots of cut off wheels, to noisy for me...
Start at the back of the bed, cut out a cross section between the crossmembers. Start at the next crossmember by drilling out the spot welds when your clear of the crossmember, you can start to cut out another section of floor. I had to replace 3 of the 4 or 5 crossmembers, if you don't have to use them it makes it alot easier. I just tightened the carriage bolts on the bed sides till they snapped, makes it alot easier I think you'll like the final outcome!! Ask away on the Questions, I'll try to help you out. J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-14-2006 at 08:44 PM. |
12-15-2006, 11:28 AM | #4 |
Great info, thanks folks!
12-15-2006, 11:35 AM | #5 |
if you have acess to plasma cutter cnc you could get a flat metal bed cut out, and then cut out peices to weld on top. Ive seen it done with flames.
12-15-2006, 02:54 PM | #6 |
Someone out there makes a flat bed repair panels don't they?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
