![]() Join Date: Sep 2005
new hei distributor
well after reading this post http://67-72chevytrucks.com/vboard/s...d.php?t=219568
i am thinking about buying one of his hei distributor http://cgi.ebay.com/ebaymotors/CHEVY...mZ260063342414 my question is the motor i am putting this in is a 305 with hei standart so can i use the same stock plug number gaped at .045?
Re: new hei distributor
oh heres the plug i am thinking about running http://www.partsamerica.com/ProductD...pe=960&ptset=A
or ngk yr5 http://www.partsamerica.com/ProductD...pe=960&ptset=A
River life......
I run the r45ts in mine.
i got that same dist from that same guy and have had no problems. its been in my daily driver since may. i run ac delco r44ts plugs gaped at .40. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
