12-16-2006, 11:18 AM | #1 |
Junior Member
VIN location - 62 c10
62 c10 SWB. Where are the VIN's located on this vehicle? I know my 69 has one on the frame rail, and one on the cab door opening. Are the VINs on the 62 in the same location?
_______________________________________ 62 SWB BBW (under construction) 86 Vette Convertible |
12-16-2006, 11:46 AM | #2 |
Re: VIN location - 62 c10
My 66 has the VIN tag in the driver door opening and one on the frame but not sure where and it prbably is no longer visible anyway.
12-16-2006, 12:39 PM | #3 |
Junior Member
In Kansas they look for it when you transfer the title to make sure the cab matches the frame. Just went through it on my 69. They took a wire brush to scrape away the dirt so they could check the frame number. Just hoping this 62 has matching numbers so I can title it.
12-16-2006, 12:39 PM | #4 |
Junior Member
The vin plate on my 63 is on the left side windsheild post. Open door and it should be at eye level when sitting in truck.
12-16-2006, 08:12 PM | #5 |
12-17-2006, 01:27 AM | #6 |
I have registered a few '64-'66 Chevy trucks in Johnson County, KS. Depending on who is at the inspection station, sometimes they look at the VIN tag at the door jamb and seldom they also looked to see if the number on the frame rail, adjacent to the drivers side exhaust manifold, matches.
The '60-'63 VIN tags are on the A pillar, inside the drivers door, adjacent to the windshield. Post your VIN and you can find some interesting information about your truck, i.e. year, chassis style, bed style, origin and unit number out of the production plant. Good luck with your project and Happy Holidays. |
01-08-2007, 03:37 AM | #7 |
Scrapper 1
Trust Me They Stamp Every Frame And Unless Some One Grinded It Then Its Not There But If That Did Not Happen Its There Even The Tuckers Cars That Came Out In The 50's Have A Vin # On The Frame
01-08-2007, 08:40 PM | #8 |
Say I have a 62 vin plate and title , anyone intrested?Woah! Vin number 2CXXXK132713,But the title says 2CXXXK123713, My Mother has had the truck since 77, and I just found the mismatch..........
01-08-2007, 08:41 PM | #9 |
Oh the vin plate is located on the drivers side door post, eye level........
01-09-2007, 04:13 PM | #10 |
C10 now is a GMC
On my '62 C10 the vin on the cab is on the "A" pillar, and there is a bunch of numbers on the drivers side frame rail right above the IFS saddle. I'm not sure if this is frame's vin number or not. Mine is mostly blocked because of the late model engine mounts i'm using on the 350.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
01-09-2007, 04:27 PM | #11 |
Chevyboy NIce truck, I have Family in Modesto /Ceries ...............I WENT ,TO SALVAGE YARD LAST YEAR, SOUTH OF of Modesto, Lots of old cars...........
