Old 12-20-2006, 07:18 PM   #1
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
Has anyone....?????
Has Anyone converted over from a th350 to a th400 in there K5 or Jimmy?
Angelse68cal is offline   Reply With Quote
Old 12-21-2006, 02:01 PM   #2
pharcyde05
pharcyde05's Avatar
Re: Has anyone....?????
I changed mine out
pharcyde05 is offline   Reply With Quote
Old 12-21-2006, 02:01 PM   #3
gmcman7202
Active Member
gmcman7202's Avatar
not that a big a deal to do.
gmcman7202 is offline   Reply With Quote
Old 12-21-2006, 02:02 PM   #4
hotrodhomi
hotrodhomi's Avatar
mine has a th400
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 12-21-2006, 03:18 PM   #5
Angelse68cal
Cochino_Racing_909
I am talking about changing it in a 4X4! Oh yea and wht is Axel Wrap?
Old 12-23-2006, 06:29 PM   #6
JimKshortstep4x4
We don't have a TH 400 in a Blazer but we have one in a short box 4x4. Since the TH 400 is longer there are some mods to be made in addition to the transfer case adapter, (the NP 205 is the same for both tranny's). The longer TH 400 requires a longer front drive shaft, a shorter rear drive shaft and the crossmember needs to go rearward. The side mount for the transfer case has to be relocated. The transfer case shifter has to be bent in an "S" shape to move it forward. The shift linkage is different, also.
Jim
Old 12-24-2006, 09:12 AM   #7
jaros44sr
jaros44sr's Avatar
Hey Jim, thanks for the heads up and info. Just picked up my TH400 and was not sure what was involved, sounds pretty strait forward, I have a floor shift so no problem there, but how do you bend the transfer case shifter. Just heat and bend around a suitable mandrel?
Merry Christmas, J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-24-2006, 10:46 AM   #8
MNorby
MNorby's Avatar
another thing the th400 will have a 32 spline output whereas the th350 has a 27 spline output so you'll either have to change the input gear into the case or swap t-cases
MNorby is offline   Reply With Quote
Old 12-24-2006, 10:51 AM   #9
JimKshortstep4x4
We just heated and bent the shift lever. It was a lot of bending and the shift lever is pretty short by the time you get it into the right position.
We use the truck for towing a car trailer and the TH 400 works great!
Jim
Old 12-21-2006, 05:08 PM   #10
gmcman7202
Active Member
gmcman7202's Avatar
still isnt a big deal, i am not sure what t case adapters you might need, or if the splines match, since i dont know the specs of the 2 off hand, as gm made the needed adapters, as the t case used is gona be diffrent for diffrent years, ect...
Old 12-28-2006, 07:49 AM   #11
vtblazer
vtblazer's Avatar
Why do you want/need a th-400 when a properly built th-350 could work just as well?
Shift points are different, first gear is higher and they rob more power from the drive train.
Flame suit on
vtblazer is offline   Reply With Quote
