12-21-2006, 02:29 PM | #1 |
Towing
Hey all I have a 71 c10. I want to make this truck into my everyday truck. I have a 12ft trailer that i will be pulling with it. Some times with a camaro on it. The truck has a 350/350. What should I do to make this truck able to tow. I was thinking heavy duty springs, with bags or air shocks.Any help would be great.
Will not be towing all the time just now and than maybe 4 or 5 times a year |
12-21-2006, 02:31 PM | #2 |
Re: Towing
i have a friend of mine with a 67 that does the same stuff but all he did was put on a tow packae for his hitch and then put them heaveduty
air shocks on it |
12-21-2006, 03:19 PM | #3 |
Re: Towing
its is a coil rear or leaf spring?
12-21-2006, 03:22 PM | #4 |
Re: Towing
He converted his over to a Leaf mind ie a leaf as well i have a 72 GMC with a fron end chevy converson done and i have coil up fron disc brakes and read drums with leafs in the back i have the air shocks on my rear and theres time i care some good loads and have no problem u may be able to just buy some harder more heay springs i know they make them
12-21-2006, 10:52 PM | #5 |
Re: Towing
it has coil springs. I think I'm going to go with HD springs and air shocks.
12-21-2006, 11:18 PM | #6 |
turbo enthusiast
Re: Towing
sorry to hijack :tj: but was wondering, is it better to tow with coil springs or leaves?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting " |
12-21-2006, 11:24 PM | #7 |
Re: Towing
Leves are smoother
12-22-2006, 03:35 AM | #8 |
Re: Towing
leves are smoother towing but normal riding around coils are better
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 12-22-2006 at 03:35 AM. |
12-22-2006, 04:17 AM | #9 |
Yup, I'm comp-useless
Re: Towing
If you were to use urethane bushings in the rear suspension (trailing arms, and panhard bar) that should solidify the sway that you feel with coils.
I'm not sure if helper bags are specifically made for 67-72 trucks, but where there's a will, there's a way. |
12-22-2006, 04:25 AM | #10 |
Re: Towing
I can't imagine that you would have any problem pulling that around. Is the camaro a show car or race car or something?
12-22-2006, 10:00 AM | #11 | |
Re: Towing
I use my 68 short-fleet to pull my 18ft steel floor car hauler. The truck is lowered @ least 5/7 but I have air-bags to adjust the height back up when the load is added. I only tow something every now & then but use the trailer regularly for moving other 'stuff' (funny how many friends you have when they know you have a trailer). I upgraded to disc brakes up front & made sure the trailer has working brakes as well cause a 1/2 ton truck isn't going to stop a loaded trailer itself. Other than those upgrades, swapping to urethane bushings is a good idea & adding a front sway bar helped too.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-22-2006 at 10:02 AM. |
12-22-2006, 10:42 AM | #12 |
Re: Towing
It might be a 14 ft can't remmber. I do know when my car is up there the back wheels are about 5 or 6 inch from the back of the trailer.
Well i would not really call it a show car but i have won some first places for my painting i did. (at camaro shows) I buy cars every now and than and fix them up and sell them so need the trail for that more. And for just hualing around crap. I have disc brakes on the truck. thanks all |
12-22-2006, 10:49 AM | #13 |
Re: Towing
I tow my 25' 6000 pound travel trailer with my 72 K10 with no sweat. Of course the trailer has electric brakes and I have a good brake controller and a weight distributing hitch. Its amazing how little it drops with the trailer tongue weight on it. ( I'm not gonna tow it again until I resolve my truck brake gremlins)
