Tubular Control Arms
Does anybody make Tubular Control Arms for our trucks besides DJM?
I was looking at the DJM product, and it seems they only come with a 3" drop lower Control Arm, which would be awesome if i was trying to lay my frame on the ground, but i'm not. I'm open to the idea of swapping to the 73 and later design, but it isn't absolutely necessary since my 72 has front discs already.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 12-22-2006 at 03:39 AM. |
Designated A-hole!
Re: Tubular Control Arms
I didn't think they used trailing arms after 72.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Yup, I'm comp-useless
Are you planning on bagging the truck? If you are Air Ride Technologies makes control arms.
If you are doing a static drop, why not look into spindles? |
blood type; Retumbo
Designated A-hole!
Okay, I'm stupid.
Not trying to highjack the thread, but I have dropped spindles and cut springs and mine just doesn't seem like it handles as well as before. Would tubular contol arms make your handling any better? If I decide to bag mine would it be a good idea to buy a set?
#7 | |
brothers that a good price on them arms though! ![]()
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
#8 | |
![]() Join Date: Jul 2006
I used stock spindles when I went to front disc and used lowered springs. I also installed fairly stick gas shocks and a sway bar. It handles like it's on rails. |
#9 | |
Thanks |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#11 | |
The LuvShack Garage
We carry tubular lower and upper control arms. Here is a link to each of them.
http://www.brothersonlinestore.com/p...number=LCA7200 http://www.brothersonlinestore.com/p...number=UCA7200 Remember, 10% off sale ends Dec 31
1967 Chevy Short/Fleet 1969 Chevy Short/Step 2004.5 Dodge 2500 4x4 Cummins 6spd |
#13 | |
" Microsoft VBScript compilation error '800a0401' " ![]() I'm not planning on bagging my truck, which is why i'm looking for an alternative to the DJM lower arm. I'm interested in tubular arms, because they look cleaner, and as i understand it, are lighter and stronger than the stock arms. I'm building my truck from the frame up, and would rather do it right the first time. and considering the cost of having my old arms blasted and powdercoated, then replacing all the bushings, there's not much difference between a new set of tubular arms.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
Stronger? Most likely.
Lighter? I don't think so..... I weighed my ART Strong-Arms vs. stockers & they were 2~3lbs heavier. Jkade, I question the logic that 'cut down coils affected the handling on the truck'. Trimming 1 coil off would increase the overall spring rate roughly 10~20% depending on the coils wire thickness. This increase in spring rate along w/a slightly lower COG are good for handling. I would be more apt to say the decrease in handling is because other factors weren't optimized..... mainly the alignment. How good was (is) the alignment? How good are the shocks? And most importantly (when it comes to handling), how good are the tires?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-24-2006 at 02:14 AM. |
#15 | |
I am thinking about getting the ART arms for this very reason. Nobody seems to stock the front parts and when it's all said and done, it's only about $100 difference for all new vs. rebuilding. |
#16 |
id like some lower tubular arms like the ones brothers sells.. that work with springs and not bags, but the whole "wont work with sway bar" thing scares me off... any suggestions?
-1947 3100 -1968 C10 -1970 K20 |
#17 |
Parts and more parts
CPP (Classic Performance Products) ( http://www.classicperform.com/ )makes a tubular arm setup, as well as many other parts for the trucks. There was a big article in "Truckin" magazine Volume 32. at the end of last year on their products.
#18 |
I purchase a set of upper and lower tubular control arms fro CCP, but I haven't put them on yet. I also purchased their tubular trailing arms also. They are nice products and I can't wait to install them.
#19 |
village idiot
will ART or CCP control arms work with drum brakes?
I like the ol' drum brakes,there excitingly dangerous nature appeals to me (lol!)so I don't plan on swapping to disc anytime soon but would like to slam or possibly bag the front of my truck Thanks |
#20 |
You can bag your truck without converting to discs or tubular arms. Just get the Suicide Doors brackes and swap bags out for your stock springs. Without drop spindles, you can still get your truck down and have the sweet ride of air.
Even if you go with a tubular arm, you will still need to either make or buy a bracket for the top. My front disc kit was $550 and I would have rather done that before even thinking about tubular arms. |
#21 | |
village idiot
#22 | |
You could always swap the upper arms side to side & flip them over for a less aggressive BJ angle @ full drop. There will need to be some 'clearance' work on the upper a-arm mount & the arms themselves, but both are easily accomplished @ home w/a small grinder.
#23 |
bringin it back.... does cpp make lower arms that accept a factory sway bar(bolted right to the arm, not linked), coil spring and not a bag? and not an arm that lowers, as ive heard that lowering arms conflict with dropped spindles, which i also have. cause thats what i want. if not. could someone please direct me to somewhere that does thanks!!
-Mike
#24 |
Questionable
CPP makes them, and they look to be excellent quality. There was a huge writeup and install using all tubular CPP products in one of the two classic truck mags over hte past couple of months.
CPP sells a swaybar to go with their setup. I'm telling you - I called these guys - they will not hesitate to lead you in the right direction, great tech help over the phone. I highly recommend calling them if you have questions.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 01-12-2007 at 05:28 PM. |
#25 |
ok. so i know who ill get the arms from then. but just to clarify, i cant use my junkyard 73+ 1 1/4 bar cause the mounts are different? i would really like to not have to dish out more $$ for if a bar if i already have one... thanks for the help!
