Intermediate Shaft Grease
What kind of grease or lubricant would you use on the rubber piece of the intermediate shaft?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
blood type; Retumbo
Re: Intermediate Shaft Grease
if you are referring to the bell at the top by the column then I would say wheel bearing grease. but I could be wrong.
Yep I am referring to the bell at the top. Sorry about that.
![]() Join Date: Jul 2004
I would vote for wheel bearing grease also, and maybe make it high temp wheel bearing grease. When it gets hot under the hood, I would not want cheap gun grease seperating into oil and leaking all over.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Not a bad nut after all..
Sorry if this is a dumb question, but how do you grease it?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
blood type; Retumbo
you can remove the clip and slide the boot off to gain access to the internals. just be careful no to extend the plunger too far or the square pieces will fall out. on mine I took the whole thing apart and drilled it for a zerk. keep in mind some grease will migrate down the shaft over time.
