12-28-2006, 10:52 AM | #1 |
Front End Suspension Rebuild Kit
Over here from the 60-66 forum, swapped in a 86' front end in my 62' to replace the factory torsion bar setup.
need to rebuild the front and was wondering who you can recommend for complete kits. Thanks
________________________ 62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 |
12-28-2006, 01:36 PM | #2 |
Formerly LSC71
Re: Front End Suspension Rebuild Kit
I've used the kits from PST before and had very good luck with them. Otherwise just piece it out from your local auto parts store.
12-29-2006, 04:43 PM | #3 |
Until Seventy Times Seven
As LSC71 said, PST has a good reputation.
But, when I rebuilt my front end, I wanted to maintain the stock rubber bushings. I purchased the control arm bushings and the center link from a dealership (AC/Delco parts) and the remaining parts from the local auto parts store (Perfect Circle). BTW, Federal Moog is a good manuafacture of suspension parts. Here's a past thread on rebuilding the front suspension, http://67-72chevytrucks.com/vboard/s...d.php?t=189574. I have a couple of procedures on replacing the upper and lower ball joints in detail, if interested.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
12-29-2006, 04:55 PM | #4 |
Why the stock bushings as opposed to a poly-urethane or poly-graphite? Or did the kit come with crappy rubber bushings?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
12-30-2006, 05:50 PM | #5 | |
I went with rubber bushings because I wanted to absorb as much road vibration as possible... an advantage over the polys. But, at the same time, they have a bit more flex than the polys. A disadvantage if you're looking for performance.
12-31-2006, 11:30 PM | #6 |
I have a 65 how hard is it to swap the front end from a 77' i know it looks like a bolt in swap but just checking before i tear it down.Thanks
01-02-2007, 02:21 AM | #7 |
i have a 64 with a 77 front suspension in it. The previous owner did it but told me the crossmember was bolt in, u just have to elongate 2 holes. other than that he said it was a piece of cake...take it with a grain of salt though as I have no firsthand experience with the mod.
Check out chevytalk.com as the 60-66 forum over there is very active and this topic has been beat to death over there 100000000+ times and those guys will be able to give you all the details for sure... Nate |
01-02-2007, 11:18 AM | #8 |
Formerly LSC71
The only thing you really need to swap are the control arms and the spindles. If you use the 77 parts they should bolt right up to the 65 crossmember.
12-29-2006, 08:42 PM | #9 |
Happy to be here
Go with poly-graphite from PST. Do not use straight urethane bushings unless you enjoy squeaking noises...
12-29-2006, 09:32 PM | #10 |
just bought a front end kit from pst this afternoon.
woohoo. |
12-30-2006, 12:34 AM | #11 |
Thanks everyone, I appreciate the information!
01-02-2007, 10:38 AM | #12 |
p-s-t has the rubber kits...
