The converter had a quart in it, when I put it in, but now how much does the rest of it hold? It is a fresh rebuild with a stock pan......Thanks
69 C-10 Pro Street...........red on black...........big block and a lot of go fast stuff under the hood ![]() Still in progress ........... |
A th350 holds 11qts. total.
No, Its not a 454 |
its all about the +6 inches
They hold just enough to soak you, every tool you own, and about 3/4 of the pavement in your driveway.
11 qts sounds right. I would start off with 9 or so, then slowly add more with it running and warmed up. |
Captain CAAAVVVMMMAAANNN!
be sure to cycle it through the gears to insure all the "pipe spaces" are filled with fluid and air burped out, could make a little differance in capacity..
72 LWB Fleetside C10 Custom 350/350 97 GMC Yukon 4X4 SLT Anna, Texas check out the project old yeller |
longhornmail, you are sooooooooooo right....I still can't get this %$#@% stuff outta my hair.........lol...........tools will never rust though.......;0
LOL! I know, i serviced 3 trannys today at work. I washed my hair 3 times, still dirty.
