Old 01-03-2007, 04:00 PM   #1
rodstored-72
chevy truck fan
rodstored-72's Avatar
Mid '90's Steer. Wheel ???'s
Hey Guys,
I Was Wondering If A Aftermarket Steering Wheel Would Fit On My '72 Chevy P/u. I Want To Know If There Would Be Any Mods That I Would Need To Do To Get It To Fit? I Have A Stock Non-tilt Column.
Thanks!!!
Rodstored-72
rodstored-72 is offline   Reply With Quote
Old 01-03-2007, 05:08 PM   #2
bobthecop
bobthecop's Avatar
Re: Mid '90's Steer. Wheel ???'s
Should fit just fine with an adapter kit
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 01-03-2007, 05:15 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you lookin to do a mid 90's wheel... or aftermarket?
Old 01-03-2007, 10:44 PM   #4
rodstored-72
chevy truck fan
i can get a really nice aftermarket wood steering wheel from a mid 90's suburban & i was wanting to know if i get the adapter that is on it now if that is all i need or if i need to just get the wheel & then buy a new adapter to fit it to my stock steer. column?? sorry for any confusion. does any body know if i need the adapter that is on it now or if i need a new one to fit it to my column.
thanks!!!!
rodstored-72
Old 01-04-2007, 01:23 AM   #5
Longhorn Man
to do it right, you'll need a correct adapter.
Old 01-04-2007, 04:13 AM   #6
1tonswb
1tonswb's Avatar
I just put a 95 chevy truck wheel on my 67 and it bolted right on.
1tonswb is offline   Reply With Quote
Old 01-04-2007, 08:51 AM   #7
68Stepbed
68Stepbed's Avatar
The adapter on the burb should work just fine. Exactly what year burb is it? Most GM columns use the same adapter from 64-94. Can you get a picture?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-04-2007, 10:09 AM   #8
rodstored-72
chevy truck fan
thanks!
i was thinking that it would work. i will go down sat. & get the wheel & the adapter. i am not sure as to who the manufacture is (grant??) that was my main concern. i wouldn't know who to get the correct adapter from. i knew that some people here had changed to the newer wheel, i just didn't know what was done to make it work..
thanks again for the help!!
rodstored-72
Old 01-04-2007, 12:08 PM   #9
Tink
Tink's Avatar
Well, the grant adapter in my 69 is different then the one in my 91 S10... they looked similar, but the one from the 69 wouldn't fit in the 91... didn't try it the other way around though.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 01-04-2007, 04:47 PM   #10
Longhorn Man
the column on the later ones are larger in diameter, and the flat black adapter cover is sized to match the column. If you use a late model adapter, on an early column, it won't work.
If you use a late model steering wheel, it normally goes unnoticed since it is such a minor detail, but the base of the wheel is bigger.
Old 01-04-2007, 10:53 PM   #11
rodstored-72
chevy truck fan
longhorn,
i am not quite understanding. if i read your info. right then will the wheel fit w/o an adapter but wont fit flush(line up) on the column (at the base). i guess what i am wanting to know is if i get the wood wheel then what do i need for it to work or will it? if it is going to be a big fabrication item then i won't mess with it. i know i have seen it done on other trucks on the board, i just don't have a clue as to what is involved??
all-
thanks again for all the patience & help!!
Old 01-04-2007, 11:47 PM   #12
Longhorn Man
take the adapter, it probably won't work. If it does, then great, if not, then all you'll need is a $20 adapter kit.
