Old 01-04-2007, 06:56 PM   #1
bad72c10
bad72c10's Avatar
Plug wires and Hooker Headers
Hi guys I just ordered my Hooker Comp Headers with 1 5/8" primaries to 2.5" collectors. My question is, do I need to run straight boots or can I run a 90* boot if I run them along the valve covers. Thanks, Justin
bad72c10 is offline   Reply With Quote
Old 01-04-2007, 07:31 PM   #2
pkj
Re: Plug wires and Hooker Headers
i have same set-up. found 90s work best. third plug back on d/s works best if you point boot straight down i then used a straight wire seperater and twisted 90 degree and hooked one end to a brake line, or depending on looms you use you can swap 3 and 4 as they come up to valve cover. still keep number 3 pointed down. both ways keep them off header and look neat and uniform. i could e-mail you a pic if you need.
pkj is offline   Reply With Quote
Old 01-04-2007, 08:31 PM   #3
bad72c10
bad72c10's Avatar
Wow that's exactly what I was looking for, someone who had this setup. If you would, please email me some pics at xtshooter@msn.com Thanks, Justin
P.S. What looms are you using? I was thinking about a vertical holder that runs along the valve cover.
Old 01-05-2007, 05:01 AM   #4
Mudder
Mudder's Avatar
I am careful to keep the wires snug from the plug to the looms. I and using MSD's. Some wires like Taylors have pretty big boots that are very close to the headers.
Mudder is offline   Reply With Quote
Old 01-05-2007, 01:29 PM   #5
pkj
i e-mailed you pics. did you get them?
Old 01-05-2007, 02:27 PM   #6
bad72c10
bad72c10's Avatar
pkj, it looks like I haven't gotten them yet, not sure why, prolly something on my side?
Mudder, are those coated Hookers?
Will a loom like this work well? Here is the link to the page: http://store.summitracing.com/partde...D1101%2D90%2DP
Thanks for your help guys.
Last edited by bad72c10; 01-05-2007 at 02:35 PM. Reason: put a bigger pic for the looms.
Old 01-05-2007, 03:13 PM   #7
Mudder
Mudder's Avatar
Yes they are coated headers. Done by Airborne Coatings in Okla for a little over $200 for the pair. Send them to them and there is about a 2 week turn around. You can actually use Scotch Bright pads on them and polish like you would aluminum. I wouldn't recomend anyone else. The guy that runs this company if I understand correctly was one of the founders of Jet Hot.
Old 01-05-2007, 03:28 PM   #8
bad72c10
bad72c10's Avatar
What do you think of those looms, Mudder? Will they hold the wires in about the right place? Thanks, Justin
Old 01-05-2007, 03:44 PM   #9
Mudder
Mudder's Avatar
The looms ofn the six looks like they would work real well. Not so sure I would run them the way they have them.
Old 01-05-2007, 06:44 PM   #10
71chevylowrider
71chevylowrider's Avatar
I have the same Headers, here's a shot of mine from the passenger side, sorry i don't have a picture showing the driver side. I hope this helps a little.
71chevylowrider is offline   Reply With Quote
Old 01-05-2007, 07:23 PM   #11
bad72c10
bad72c10's Avatar
OK pkj, I did get your pictures now. Thank you for sending me those, those help alot. That is going to be an awesome little truck! I really like that Air Cleaner! Thanks to you other guys for postin pics, it seems like everyone's doing just about the same deal.
Not that it really matters now since I already ordered mine, but I'll ask anyway, Do you guys like your headers?
Also, did anyone use the supplied power steering pump spacer? Hol long of a bolt will I need to use that?
Thanks, Justin
Old 01-05-2007, 07:40 PM   #12
71chevylowrider
I love my Ceramic Hookers, they look great now after being on the truck for 4 years or so, & they sound great with my 2.5" exhaust & flowmasters, & since their the shortys, they keep my exhaust up off of the ground. I can't answer the bolt question, I didn't install it.
Old 01-05-2007, 08:26 PM   #13
67sss
67sss's Avatar
anybody run the wires down and toward the firewall?
67sss is offline   Reply With Quote
