01-09-2007, 04:46 AM | #1 |
Bench seat differences.
I just purchaced a second truck and it's bench seat is different than my other truck.
My first truck-67 C10 has a bench seat that can fold forward. It has a stud with two nuts (for adjusting seatback angle) and a wing nut to hold the seat from tipping forward when you do not want. My new truck-67 K10 is a fixed back seat and cannot be tilted. Were both styles available or is my tilt back seat out of something different? Possibly it is out of an older pickup or possibly a panel/suburban? Thanks
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
01-09-2007, 07:59 AM | #2 |
67-72 Addict!
Re: Bench seat differences.
My seat flips forward but it has a lever on each side to release it from the catch.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
01-09-2007, 10:33 AM | #3 |
My flip down seat has the wing nut arrangement on both sides. Both of the K10's that I looked at were fixed seats.
01-10-2007, 10:43 AM | #4 |
Thank you 70c10, I have not seen one like that. What do other people have in there trucks? Or does everyone have buckets?
01-10-2007, 12:08 PM | #5 |
I've owned a '69 C-10 and a '71 K20. Both seats were fixed. Phil
01-10-2007, 12:22 PM | #6 |
"Trucks with Class"
67-8 flipped forward and there were two different ones (cheap springs & full foam).
69-70 were solid (again a cheap & dlx) 71-2 were solid, but different from the others (again a cheap & dlx) When you buy new seat covers, be sure you know which seat you have or they won't fit. The ones that have levers/latches to release them are 73+ |
01-10-2007, 01:40 PM | #7 |
67-72 Addict!
Heres a closeup of mine.
01-10-2007, 04:03 PM | #8 |
In Memoriam...
My '68 c10 has the fold-up wing-nut arrangement.
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
01-10-2007, 04:19 PM | #9 |
THE VILLIAGE IDIOT
hmmm,,my 68 gmc has a folding seat,,but doest have catches on it,,you just pull it forward...
honestly honey,,i have no idea how that truck got here. |
01-10-2007, 07:49 PM | #10 |
God Bless Mr. T
All of the rigs I've owned/driven have been non-tilt.
'65 GMC '72 C/10 '72 K/10 All fixed.
Like a midget at a urinal...sometimes you must stay on your toes. |
01-11-2007, 12:17 PM | #11 |
I am needing a new seat (or some serious repair to the existing one) in my '70 C10. One that tilts forward would be great as I am removing the gas tank from behind the seat. I noticed PICKMUP mentioned the '73 and newer seats tilted forward. Anyone have any idea how hard these are to adapt to our trucks? Hope I am not stealing the thread, this just seemed a good place to ask.
01-11-2007, 07:24 PM | #12 |
68 C10 Longbed
I have a 71 Custom Deluxe C10 and it has a fixed seat.
01-11-2007, 08:44 PM | #13 |
Firefighter
Both of my 67's have the seats that flip forward.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
01-11-2007, 09:54 PM | #14 |
Too Dumb To Know Better
My nephew's 68 has the same setup as the first picture. They are a better deal than taking out the rear bolt on your fixed seat. One of my trucks has a folding set setup like that. Not the best, but it works.
01-11-2007, 09:59 PM | #15 |
Wrenchin & Sandin!!!
my 71 C10 is a fixed seat.
Randy Shorewood, IL. My Favorite eBay Searches My Driver Restore Thread 1971 C10 Longbed 2005 Silverado Shortbed 2005 FXDWG |
01-12-2007, 01:19 AM | #16 |
Too many projects
Would the spring vs the full foam seat be worth more?
My 1970 GMC had one that appeared to have the original style vinyl (could have been an earlier seat, but likely not). When I took it out I noticed that it had springs with a thin layer of foam on top of it. Also had a fixed back. Gracias.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
