01-13-2007, 01:39 PM | #1 |
Front crossmember issues
Hey guys, I'm trying to lay out my 63 longbed, the rear of the frame is done, but I need to take care of the front end issues. I already have 2.5 inch drop spindles, but I am hitting the crossmember/arms on the ground when I lay it out up front. Anyone know of any front end swaps that can be done on a buget of cheap that will allow me to have a higher front crossmember? Any help is greatly appreciated! I will post some pics of how its coming along later.
01-13-2007, 01:54 PM | #2 |
Active Member
Re: Front crossmember issues
if you have the cash flow you can do the dropmember
or z the frame |
01-13-2007, 05:05 PM | #3 |
Yea, a dropmember would be awesome, but cash is an issue here. I thought about z-ing the front end, but might not be the best idea. I was just wondering if any other otions were out there.
01-13-2007, 07:00 PM | #4 |
Active Member
not to sure but maybee tubular control arms and help with the issue
01-13-2007, 07:06 PM | #5 |
What about sectioning the stock crossmember. Saw one done here, i think they sectioned 1 3/4" . It looked great and super cheap if you can cut and weld. I probably saw it in the 67-72 truck section as thats where i spend most of my time.
Jason |
01-13-2007, 07:24 PM | #6 |
here's a link to a sectioned crossmember
http://67-72chevytrucks.com/vboard/s...d.php?t=189894 |
01-13-2007, 08:10 PM | #7 |
There is also a sectioned crossmember in a thread started by fletch4x4. I cant seem to figure out how to link it but i search for crossmember section.
HTH Jason |
01-14-2007, 02:42 PM | #8 |
SIR
.....check the latest issue of "classic-trucks" ...and hope you win the lottery....
66long low fleet http://community.webshots.com/user/LVNR66 |
01-15-2007, 04:48 PM | #9 |
If you are going to go through all that cutting and welding, I would Z your frame instead of sectioning the cross member. IIRC you can only section the cross member about 1-1/8" without running into issues like tie rods hitting and stuff like that. They both have their headaches, but to me Z-ing is less of a headache and you get more drop. I Z'd my '63 frame 3" and I'm running 3" dropped spindles with bags. The frame hits the ground before any part of the front cross member does. Just my 2 cents. Check the suspension forum for more ideas.
