01-13-2007, 01:42 PM | #1 |
Is it true that .....
IF these trucks came with a 350 it would automaticly be a 4-bolt main engine?
72 Cheyenne Super 80 Silverado Blazer 2wd |
01-13-2007, 01:44 PM | #2 |
Re: Is it true that .....
false
01-13-2007, 02:00 PM | #3 |
The 1 tons more than likely. I took a 350 out of my 69 GMC 1 ton. It had/has a 4 bolt main with a steel crank.
01-13-2007, 02:03 PM | #4 |
Designated A-hole!
I've had a few and they were all 4 bolts, but that's just my experience.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
01-13-2007, 03:48 PM | #5 |
Every 69-72 chevy truck I have had that had the original 350, or one of the 69-72 PICKUP era, was a 4 bolt main. I am fairly sure that is TRUE!!
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
01-13-2007, 05:06 PM | #6 |
4 barrel most likely 4 bolt mains. 2 barrel most likely 2 bolt mains. Ripped apart a 71 chevy with original 350, 2 barrel, and it was a 2 bolt main engine.
01-13-2007, 10:56 PM | #7 |
Well, that about 1/2 and 1/2, but no definite answer. I was wondering because I have been selling engines like crazy and most people seem to want 4 bolts. Is pulling the pan the only way to tell for sure?
On a side note, I wonder if I am selling these engines too cheap. I have been getting about $400 for a complete non-running 350 engine right out of a truck, and have sold every one of them I can get a hold of.
01-13-2007, 11:08 PM | #8 |
turbo enthusiast
WOW!!
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting " |
01-14-2007, 09:06 PM | #9 | |
Usually in sales if you sell 100% of your inventory your price point is too low. For example selling 100% of your engines for $400 is too low. Try adjusting you price points higher until you reach 85-90% So if you charge $500 per engine and only sell 90% of you are about right, then if your inventory of the remaining amount drop your price a little or hold on to them for a while if you can. |
01-15-2007, 02:06 PM | #10 | |
01-15-2007, 03:06 PM | #11 |
Global warming is a myth
I heard once a long time ago that all of the GMC's came with 4-bolt mains, 'cause GMC only sells trucks, they would go a little out of their way to make sure they could justify someone buying a GMC over a chevy. FWIW.
In my blazer, with a 2-barrel original 350, it was a 2-bolt main. Personally, if I were going to build a small block from stratch I'd prefer the 2-bolt because of this. When you are doing a full rebuild on an engine, it is totally worth it in my mind for the added assurance that this little mod would provide. Granted, it's a 3-400 dollar upgrade, and maybe it's not really needed for a truck motor, but when you decide to go all out with the supercharger or nitrous, you sure wouldn't have to worry about the bottom end here. Later, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's |
01-14-2007, 12:02 AM | #12 |
THE VILLIAGE IDIOT
well id say if you tore it down and went through the block,,you would get more..might get more even with out the work..since everybody wants a 4 bolt main
honestly honey,,i have no idea how that truck got here. |
01-14-2007, 08:31 AM | #13 |
Six of one half dozen of the other.
I have always had to use the engine code on either the back of the engine or on the front near the water pump Most that I have torn apart were two bolts
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" Last edited by 72armyswbtruck; 01-14-2007 at 08:31 AM. |
01-14-2007, 02:55 PM | #14 |
I thought a quik guide was the harmonic balancer, if it was in the 8" range then that would say 4 bolt main to me. jm2c. other opinions? J.
01-14-2007, 03:03 PM | #15 |
I am a Referee of life.
I see a lot of fairly knowledgable people looking for 4 bolt mains to build.I have to wonder why since if you are building for major power,you are better off to start with a 2 bolt and have it machined for splayed 4 bolt caps.The main reason given for this is that the webs of the 2 bolt are stronger and the splayed caps are even stronger than the factory 4 bolts.If someone were building a serious engine with the cost involved I would think buying the caps and having it machined would be a fairly simple and cheap way to get that strength.Also it seems like most of the aftermarket blocks use splayed 4 bolt mains also.
As to whether the engines are 2 bolt or 4 I have taken a couple of original to the truck apart,One 2 and one 4 that I recall.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-14-2007, 03:11 PM | #16 |
01-14-2007, 03:28 PM | #17 |
RIP Mr Ron
Pull the pan and count the bolts. Then you know for sure.
Ron (Mr Round Tuit) Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
01-14-2007, 06:00 PM | #18 |
its all about the +6 inches
dropping the pan is the only 100% sure way
01-15-2007, 06:25 PM | #19 |
This isn't a new topic in the Chevy universe - there just isn't any other way to tell and all the rules of thumb out there (and there have been some really nutty ones!) have been disproven at one time or another.
Besides...that's part of the fun - SBC treasure hunt! As for 4-bolt vs. 2-bolt; 2-bolts are good up to 400 HP w/studs, factory straight 4-bolts to 500 - anything beyond that and you'll definitely want steel caps. If you're not turning something past 6K or using power-adders (NOS, forced induction, etc) I wouldn't sweat bullets about it. Steel caps add about $450 to the build for the caps and machining. I'll probably have to put on my Nomex for this, but I've never seen a broken cap on a STREET 2- or 4-bolt factory block. |
01-14-2007, 07:51 PM | #20 |
Drop the pan cause some of the casting numbers say 2 or 4 bolt when you look them up.
01-15-2007, 05:48 PM | #21 |
Alright Alright Alright
the original engine in my 72 cheyenne is a 2 bolt main and its an orginal 4bbl 350.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
01-15-2007, 06:13 PM | #22 |
the original 350 in my old 70 longhorn was a 4 bbl and 4 bolt high nickle (1020) block.
01-16-2007, 06:11 PM | #23 |
Sierra Grande Club
Longhorn what is a high nickle?
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 01-17-2007 at 09:18 PM. |
01-19-2007, 08:33 AM | #24 |
oil galley plug holes plugged for a member
01-16-2007, 08:43 PM | #25 |
high nickle blocks have a little more nickle in the iron than a normal block, and they don't wear nearly as fast. I took apart a caddy big block (they were all high nickle) that had a tad over 100K on the clock, and there was not only no ridge at the top of the cylinder, but you could actually see a little bit of the cross hatch from 100,000 miles ago.
that 300,000 mile (never rebuilt) 350 did have some ridge, but the pistons still came out the top by hand with no ridge reamer needed. On chevy engines, high nickle blocks can be ID'd by seeing 10 and 20 under the timing chain IIRC. In my opinion, high nickle is WAY more important than 4 bolt mains. |
