Old 01-14-2007, 02:33 PM   #1
1969k10stepside
Removing frame rivets
I have a little rust on my swb 4x4 frame.Its not rusted through but is enough to adress.It its rusty around my front spring hangers for the rear springs.I need to remove them to fix the rust problem.What is the best way to remove the rivets?I was thinking cutting torch(Indiana instinct ) What way do you suggest to remove them?
Dustin
1969k10stepside is offline   Reply With Quote
Old 01-14-2007, 02:36 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Removing frame rivets
I didn't have access to a torch. So, I ground the head down, drilled a hole in the center of the rivet, and popped it out with a punch.
I have also used an air chisel, works as good as the first way, only faster! I drilled a hole in the middle first, deep enough to go through the depth of the frame. Then I used the air chisel to pop the head off and push the rivet out.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-14-2007, 03:11 PM   #3
jugernot
Life, Be In It.....
jugernot's Avatar
I tried an air chizel, but found that drilling them out worked better.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 01-14-2007, 04:09 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
If they are easy to get to I just chisel them off and punch them out. I use a chisel that is only sharpened on one side and a 3# hammer. I find that works pretty well. Oh yea, I also wear heavy leather gloves, hold the chisel with a pair of vise grips, and wear safety glasses.... I have also used a grinder, drill, & torch. Whatever gets the job done....
LockDoc
Leon
Old 01-14-2007, 04:11 PM   #5
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I have used both the grinding method and drilling them out as I don't have a torch either. I found that, depending on how stubborn the rivet was, grinding the head off didn't always work. Sometimes the other side of the rivet gets stuck pretty good and no amount of beating can convince it to move. I would have to say I prefer grinding as it is much quicker just be careful not to grind into the frame. You will need to beat the rivets pretty hard to get them to come out but most of them should go. If you have a few tough ones that just won't move, you can always drill those out after the head is removed.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 01-14-2007, 04:19 PM   #6
msgross
msgross's Avatar
grind an "X" in the head and air chisel it off. Or go the Hoosier route and use heat, be careful not to heat the frame to much though...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-14-2007, 04:22 PM   #7
byrd
Union Electrician
byrd's Avatar
I air chiseled all mine off that I needed to. It was fairly easy and olny took about 2 min each, keep sharpening the edge after ech one or every other one and it will work great. just my .02
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 01-14-2007, 05:38 PM   #8
I most recently used a cutoff wheel and ground mine down, then center punched them out. I have also done the hammer and chisel routine. Either way, it requires a bit of beating to get the rivet out. I've never had a torch (it's still on the wish list) so I don't know how that would work.
Old 01-14-2007, 06:28 PM   #9
Livrat
Member #1049
Livrat's Avatar
I routinely "wash" the rivet heads off with a cutting torch.. But.. you need to be very careful as you could end up with a mess.. then use an air hammer/chisle to push them out..
Livrat is offline   Reply With Quote
Old 01-14-2007, 06:54 PM   #10
qksilver
The torch is the easiest but you need to be really carefull you don't damage the frame or the bracket. I use it when I don't care about the metal on one side of the rivet. Otherwise to do it clean, the drill or grinding disc works pretty good. Use a good bit, low speed and a oil squirter to keep it lubed
qksilver is offline   Reply With Quote
Old 01-14-2007, 07:02 PM   #11
65-72 chevytoys
65-72 chevytoys's Avatar
I don't have a torch or a chisel so I had to grind and punch mine. I guess mine were not as stubbor as I only had to drill one of them.
65-72 chevytoys is offline   Reply With Quote
Old 01-14-2007, 07:02 PM   #12
piecesparts
Parts and more parts
piecesparts's Avatar
Grind an "X" in the head of the rivet and then the air chisel will shve the rivet head right off.
Old 01-14-2007, 07:41 PM   #13
Aarons72s
Me personally, cut off wheel to get the head off, drill to drill the center out and weaken the rivit and a couple good wacks with a punch and hammer. Good luck dustin. Some will come out easy and some will be a pita!
Aarons72s is offline   Reply With Quote
