Old 01-17-2007, 02:38 AM   #1
84 400
Sb 400 club
84 400's Avatar
Clean up the motor and compartment
Guys sorry for this question i am having a blank in my memory. I put on the Edelbrock 650 cfm thunder carb a while back and the halve covers came with a hose that conects to the front of the carb. like a pvc valve. What is the purpose and do i need to keep it? the valve covers are just cheapo pep boys ones if i remember right. Thanks.
I really need to clean the engine compartment up a bit so it looks less cluttered. any suggestion for all the wires on the intake? and others? Also i am gonna order a braided ss Fuel line kit from pump to carb from sumit and a diffrent filter.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 01-17-2007, 10:44 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Clean up the motor and compartment
My thought is yes, I would keep the hose from the valve cover to the carb base. That is your PCV valve pathway to keep your crankcase fro becoming overpressurized. The design is that you have a vent path from the opposite valve cover (whether or not it connects to the air cleaner) to pull fresh air into the crankcase. This allows for sweeping gases out of the crankcase to the intake of the engine to be burned away. If you do not run a PCV setup, then you will have high pressure in the crankcase, which promotes oil leakage at gaskets and other connections. I run a line from my passenger side valve cover to the bottom of my open air cleaner and then a line from the PCV valve on the driver's side valve cover to my carb base. I do not have any leakage so far.
If you want to clean up the top side of the motor, then move everything else that is on top of it to a corner in the engine comartment and run a vacuum source from the back of the intake to that point. That way there is very little on top of the motor and it doesn't look cluttered.
Get those spark plug wires in wire looms down the side of the valve cover (just above the exhaust manifolds and seperate them so that they are neater and that will clean up the top a lot.
Old 01-17-2007, 06:24 PM   #3
cliffsta
Stepsides RULE
cliffsta's Avatar
How much was that braided fuel line? I def. want to go with something other than rubber after all of, well, you know
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 01-17-2007, 06:33 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
When I was looking at the 1406, summit had a hard line for it that ran most or all of the way between the pump and the carb. It was summit branded, so it was pretty inexpensive as far as those things go.
Back on topic, I would keep the vent hoses from the valve cover for the reasons mentioned. You could go with vents instead, but they might blow oil on the engine. That would not be an improvement.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-17-2007, 09:54 PM   #5
piecesparts
I put this motor in my 84 GMC with the Thunder AVS carb and a solid fuel line from Edelbrock. I have the Edelbrock fuel pump on the side of the motor feeding up to the billet fuel filter that is on the Edelbrock solid feed line. The fuel line is summit's braided line with AN fittings on it for finish. I decided a while back that I was done with fuel line hose clamps. From now on I will use finished fittings.
Old 01-17-2007, 11:06 PM   #6
84 400
Sb 400 club
84 400's Avatar
Thanks for al the pointer guys. The cap on the passengers side with thte hose goes to the front of the carb but were it meeds the gromet on the valve cover it leaks alittle oil. on the drivers side i have a filter going in the valve cover. you can see it in this pic. Also Cliffsta the kit is avalible through summit carries ther own brand and also sells edlebrock version. the summit one is on page 27 of ther catilog. It is called fule pump to carb hose kit. It comes with braided line and AN fittings. part # SUM 631522 or SUM 63150.
1985 C10 LWB Sold
Old 01-18-2007, 03:56 PM   #7
86swb
Born a Chevy Man
86swb's Avatar
Looks better already. Did they have a braided line for the PVC hose? That would look good.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 01-18-2007, 05:40 PM   #8
piecesparts
That is the PCV hose on the engine that he has pictured, ISN'T IT? Rather than using a straight PCV valve, he appears to be using a breather cap. I don't know if he has a PCV valve inside it, I kind of doubt it. My thought would be that he needs to throttle down on his vacuum line to the carb a little by installing a PCV valve, not using a straight cap.
The motor that I have above has caps on the valve covers, but they are billet and there is a PCV valve inside the one cap connected to the carb base. It works better, in my mind, to have the valve in there.
Old 01-18-2007, 07:25 PM   #9
84 400
Sb 400 club
84 400's Avatar
yeah it does not have a pvc inside it. It preforms fine though. Also Clifsta : earls makes a kit too for the fule line. Peice parts: what would be the advantacge to having a pvc on this motor? Thanks alot
1985 C10 LWB Sold
Old 01-18-2007, 07:35 PM   #10
82c10
needin' money
better crankcase ventilation, i was gonna say if that thing was what you used as a pcv you want to throw it away, a stock one is better, but since it isn't you can keep it
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 01-18-2007, 07:46 PM   #11
piecesparts
I can't say for sure, but what you basically have on your motor is a 3/8" hole in your intake manifold. Granted it is sucking fumes from the crankcase, BUT it is sucking it all through 3/8" hole. The air comes in from the opposite valve cover circulates through your engine and is sucked into the intake by that open pathway. A PCV valve will limit that hole to about half of that and that in effect will make your vacuum better in your engine. The motor should idle better, run better and the mileage may (I say May) get better. Acceleration may improve, due to more vacuum available to pull the advance quicker. A PCV valve is a slight restriction designed to work with the engine to make a balance in operation, what you have is larger than design. Also the PCV is a check valve, so if the motor backfires it will not blow flame into that oil rich atmosphere inside your crankcase. I haven't seen a crankcase fire for quite some time, but it happens and it is something to try to put out.
Then again, I could be wrong.
Old 01-18-2007, 11:01 PM   #12
86swb
Born a Chevy Man
86swb's Avatar
OK, I stand corrected. I did not see the PVC. I thought the black hose was going back to the PCV. Anyway, the other hose would look good also in the braded from Summit.
Old 01-19-2007, 01:37 AM   #13
84 400
Sb 400 club
84 400's Avatar
Well Thanks peice parts for giving the explination and maybe i can take some pics of the inside of that thing tomarrow and the new filter on the other side. Those pics are old. Anyways the truck runs very smooth. idle is perfect and dang the thing will roast the tires!! well one tire.... It really has no cam in it. If i can figue how to make a small vidoe i will some time so you can hear it. But my uncal told me you don't really want a camm in this motor.
As for the fuel line it is more for saftey. I gotta replace the glass style filter and thought i might as well do thebillet aluminum flow through from sumit or earls.
1985 C10 LWB Sold
