Old 01-17-2007, 10:21 PM   #1
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Crossmember question..
Can I leave my stock manual trans crossmember in, and put in a auto trans crossmember for the th400 to bolt to? Would that work, I wanted to put some kind of scatter shield support off of the manual xmember, but I dont have a trans to look at and measure. Does anyone know?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 01-17-2007, 10:28 PM   #2
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
Re: Crossmember question..
is it a 3 spd on the tree or a 4 spd toploader style trans? the reason i ask is the 3 spd style trans has the crossmember closer to the front and to switch to an auto you'll have to grind torch or cut the rivets out of that x member to get it out of the way for the auto to fit
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
Old 01-17-2007, 10:41 PM   #3
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Ah, well that ditches my idea of doing that then. How hard is it to get the manual xmember out without air tools, or a torch?
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 01-17-2007, 10:54 PM   #4
lilpup69chevy
67-72 parts finder
well a grinder would work just grind it down to where you can take a hammer and a punch and get them out, someone torched mine out but they were stupid and just took the torch and cut the member leaving the rest still riveted to the frame, so when i get around to it i'm gonna take a torch and blow the rivet heads off, either way a grinder and a punch should get the job done just watch your fingers!!!!!
Old 01-17-2007, 11:13 PM   #5
GMCMAX
Active Member
GMCMAX's Avatar
If you don't have a grinder, you can center punch the head, drill a 1/8" or slightly larger hole all the way through, then drill with a 3/8"-7/16": the head will come off and you can punch the rest out. Worked for me on mine.
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 01-18-2007, 02:53 AM   #6
ghetto_superman
ghetto_superman's Avatar
lilpup its crazy how many people actually leave chunks of crossmember in the frame.. i dont think i could slep at night if i knew i left all that garbage in there...
-1947 3100 -1968 C10 -1970 K20
ghetto_superman is offline   Reply With Quote
