Old 01-18-2007, 09:39 PM   #1
isenegger
lowering the rear
i lowered the front of my 76 with 2" drop springs now i want the rear down 3" i was thinking a 2" shackle and remove a leaf. what do yall think.
isenegger is offline   Reply With Quote
Old 01-19-2007, 01:18 AM   #2
chopper103in
chopper103in's Avatar
Re: lowering the rear
lowering blocks
chopper103in is offline   Reply With Quote
Old 01-19-2007, 11:25 AM   #3
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Sounds like that should be about right. You might want to have the spring re-arched to give you the drop you're after. The problem with taking out leafs is that your suspension will start to get spongy and if you have any kind of load in the back it gets even worse.
Originally Posted by chopper103in View Post
lowering blocks
Lowering blocks won't work on a leaf spring suspension because the factory position for the spring perch is on top of the axle. Unless the axle is flipped to the bottom (which would drop the truck about 5"), any block installed between the axle and the spring will raise the truck. This is a pretty common way to put a rear lift kit on a 4x4.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 01-19-2007, 04:49 PM   #4
chopper103in
Lowering blocks won't work on a leaf spring suspension because the factory position for the spring perch is on top of the axle. Unless the axle is flipped to the bottom (which would drop the truck about 5"), any block installed between the axle and the spring will raise the truck. This is a pretty common way to put a rear lift kit on a 4x4.[/QUOTE]
sorry ----my supidity
Old 01-19-2007, 02:06 AM   #5
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
pulling a leaf might give you more than an inch, but you could always play with the shackle either at the 1" spot or 2" spot, the better way to go i think would be 2" hangers and 1" on the shackle.
milehightoyz is offline   Reply With Quote
Old 01-21-2007, 02:05 AM   #6
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
No worries... Just trying to help. I have had to learn a few of these things the hard (and sometimes expensive) way. If I can help someone get their project off in the right direction, I am happy to do so.
1978 Chevy C/10 SWB
1970 Pontiac Lemans
