Old 08-24-2002, 11:47 PM   #1
palallin
How big a tire . . .
What's the tallest tire one can run on a '69 K-10 withOUT lift or fender trimming?
TIA.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 08-24-2002, 11:58 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
probably 32X10.5/15 on an 8" rim. Anything taller or wider will catch the front lip of the fender well. (I'm running 31x12.50R15s on 10" wide rims w/ 4" backspacing and with a little flex the tires hit the front lip of the fenderwell while turning.) This is even with new bushing for the stock 3 leaf springs and new poly body mounts and ORDs 1/2" longer shackles. i'm actually think of adding ORDs 1" zero add-a-leafs. I like the look of the wide tires. They are good for the sand.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-25-2002, 12:18 PM   #3
6869704X4
Before I lifted my 70 K10 I was running 33x12.50/15s on 70s rallys. No hitting anywhere and did some serious wheeling with it.
Not sure of the backspacing on those factory wheels though. I can measure them for you if you want.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 08-25-2002, 11:57 PM   #4
palallin
So, I should be OK with 31s on 7" rims?
Old 08-26-2002, 09:24 AM   #5
71BBK10
Teufelhunden
71BBK10's Avatar
most definately, i have 31x10.50's on a 15x10 wheel. no problems with rubbing
1971 K10 lwb fleetside 402 T350 205
71BBK10 is offline   Reply With Quote
Old 08-27-2002, 09:19 PM   #6
matt_field
matt_field's Avatar
im running 32x10.50 bfg K.O. tires and 15x10 ultra wheels VERY NICE SET UP... no rubbing at all, my truck even sits stock . hope this helps
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 08-28-2002, 11:21 AM   #7
Mike C
Mike C's Avatar
I ran 33 14.5 MT Bajas on my Jimmy with 15x8" wagon wheels. No rubbing. Going to 10" rims caused slight rubbing on the fenders. (both with 3.5" backspacing) You could probably get away with 4" bs, but you shouldn't have any troubles with 31 10.5 except that a 7" rim is too narrow. Get yourself a set of six lug rallys off an 80's 4x4 or some aftermarket rims.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-29-2002, 01:02 AM   #8
palallin
Why is it too narrow? (This is a genuine question; not a sm@rt-@$$ remark.) Is there danger or is it a "looks" thing?
I really dislike Ralley wheels, and I've never found an aftermarket set I like as much as the Center-cap and narrow trim rim combo I run now.
Old 08-29-2002, 08:08 PM   #9
71BBK10
Teufelhunden
71BBK10's Avatar
i don't think you'll have any problems running that tire, i ran 35x 12.50's on like a 7 inch wide wheel (however wide 70's ford trucks are) with no problems good luck
Old 08-31-2002, 11:56 PM   #10
MJN
MJN's Avatar
The only reason that 7" wheels would be too skinny is that the wider the tire is the wider the rim must be for the sidewall to be it's strongest. If you put a fat tire on a skinny rim the sidewall is vulnerable to rocks and whatever else they encounter. They will also last longer as there will be less stress on the sidewall.
Old 09-03-2002, 09:56 AM   #11
Mike C
Mike C's Avatar
It also allows you to run more PSI on the tire and still have even tire wire. With the narrow rim, the tread tends to bow up in the middle and you have to reduce pressure for even wear. This reduces the load the tire can carry. It also tendt to push the sidewall against the rim lip which means the load isn't carried on the bead in the proper area. A 10.5" tire should be on a 8-10" rim ideally, but the rim will be better protected offroading with an 8" width.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 09-03-2002, 06:13 PM   #12
71BBK10
Teufelhunden
71BBK10's Avatar
after reading my post i guess i should clarify cause it does seem a little misleading, you can get away with running those tires on a 7 inch wide wheel (if you are a cheapskate like myself) but if you have the money to spare it would be better to go with something a little wider.
